Results 1 to 5 of 5
Thread: wheel studs
    Jun 2006
    7
    Default wheel studs
    I have Bildon's 80mm studs and 15mm wheel spacers on my current setup. The 80mm studs must be used with wheel spacers (probably about 1/4 inch) or you can't tighten down an oem-style wheel because of the shoulder on the studs.
    I'm looking for the flexiblity to experiment. Can anyone can tell me if Bildon's 60mm studs can be used without spacers?
    Or can anyone can recommend another vendor that offers studs (M12x1.5) around 50-60mm length that can be used with or without spacers?
    Thanks!
    Nov 2001
    Wheaton, IL
    1,893
    I use studs that press in from the back side, and can use wheels without spacers.
    Chris Schaafsma
    Golf 2 HProd
    Nov 2004
    Ligonier, PA, USA
    1,676
    Quote Originally Posted by analog74 View Post
    Thanks!
    Ask Bildon.
    Pittsburgh, PA
    1,181
    Yah ask Bildon
    Our 75 & 80mm studs are the only studs that REQUIRE spacers. The unthreaded portion is stronger and since you would never need to use an 80mm stud without a spacer that is why they were made that way.
    Therefore our 45, 60 & 65mm studs do not require spacers.
    Volkswagen Racing Equipment
    2002, 2003, 2005 NYSRRC ITB Champs
    Jun 2006
    7
    Yah, I did ask Bildon. Twice.
    But thanks, Bill. Now I know how to get a quick answer out of you!
