Water under pressure has a higher boiling point.
The normal 212 degree boiling point is at atmospheric pressure.
The higher the pressure goes the higher the boiling point is.
That is the whole reason behind the high pressure caps.
But it also goes to say that the rubber hoses can only stand so much as Ron found out on the Mustang.
