I have a 93 mustang 2.3 na that I am getting ready for autocross season and was wondering what type of suspension components that you use on your ITB cars, and any suggestions or parts that to stay clear from too, Thanks. Morgan
Morgan,
Easily, the best advice to give for Mustang suspension questions is to refer to the "Bible", Mustang Performance Handbook 2 (Chassis), by Willliam R. Mathis. One book deals with engine and drive train...it's not the one you need. First edition was 1995, and it will explain the problems associated with the design of the Mustang. A thorough understanding of the limitations of the compromises used by Ford will make the system work much better.
Many solutions offered in the book will be beyond the rules that most IT and Solo people are stuck with, but it will give you paramaters to play within. It gives designs, and dimentions of parts to make your self.
Most off-the-shelf parts are for the GT, and don't work with the base 2.3, so read before you spend.
I've set up two M3s for ITB, and of have ideas that we never put to the metal. There was still more room for improvement.
Good racing.
Bill
Bill Frieder
MGP Racing
Buffalo, New York
Thanks for the info Bill. Have found the book on Amazon and should have it next week.
try dugan racing in atl ga
Morgan,
I should have emphasized that the book is written for the GT. Products mentioned are for the GT. You will have to find comparable products (brake pads, shocks, etc) specifically for the four cylinder, and therein is the challenge. Not insurmountable, just challenging.
Keep in mind that the two models share sheet metal, but many critical components (rear diff housings, front uprights, brake components) are specific for the GT.
The information applies to both versions, and is correctable using the same theory application.
Good racing.
Bill
Bill Frieder
MGP Racing
Buffalo, New York
Morgan, where are you located
Ron
Atlanta
ITB Mustang
