Results 1 to 6 of 6
Thread: Generator... What size?
    Jul 2006
    Prattville, Alabama
    129
    Default Generator... What size?
    What size genearotor do I need?
    I figure that my small 2hp compressor or a small air conditionerat night (6000BTU 110v) would be the biggest items I would use.
    Let's assume that travel space is an issue.
    Todd
    Mar 2002
    Black Rock, Ct
    9,594
    I don't care what size you get, but out of consideration for those around you, (The FIRST decision factor), you must get a quiet one, like the Hondas or Yamahas with dBa ratings in the low 60 or high 50s.
    From there, you can choose ...For use with an AC unit, I'd recommend, and went with, a 3000 watt unit, like the Yamaha I got. It's got auto idle, electric start, and a power smoothing circuit, and it's pretty quiet. It's also heavy, and not cheap, but it's, well, a yamaha, so build quality is quite high. Buy once, do it right.
    IT-7 #57 RX-7 race car
    BMW 2003 M3 cab, sun car.
    GMC Sierra Tow Vehicle
    lateapex911(at)gmail(dot)com
    Sep 2001
    alexandria, va
    851
    yup, what he said!
    Trussville, Alabama, USA
    1,087
    If you are going to run the compressor and the air at the same time, 3k is not large enough. The compressor will require about 1500 watts, but it will require a surge capacity of probably twice that to start. Check the amp rating on the air unit, but I think they are also around 1500 watts. So, the minimum I would consider would be 4500 watts. Honda, Yamaha, or Kawasaki ONLY!!!! If you are interested, Kubota has some killer small diesel units that run forever on fuel. Hope this helps, Chuck
    Chuck Baader
    White EP BMW M-Techniq
    I may grow older, but I refuse to grow up!
    Mar 2002
    Black Rock, Ct
    9,594
    Dump the compressor and take a tank....probably less weight, and nitrogen.
    Jul 2006
    Prattville, Alabama
    129
    I actually would prefer an extension cord if power is avavilable at the track...
    Todd
