If you don't have an LSD and can see the spider gear pins then you need to get a longer dental pick or make on yourself. If you need to make one get a longer section of coathanger (roughly 1') sharpen the end on a grinder to a point. Using a flashlight stick the pick through the axle opening opposite the stuck one. At the bottom of the bore you should be able to see the stuck axle and end of the splines, what usually happens is the C clip while sitting in it's groove kind of falls down to the lowest point in it's groove and "binds". you need to take your pick and put it under the clip, help lift it up a bit so it is centered in the groove, while holding it get a helper to "pop" the axle with a prybar, should come out much easier.
Just forcing it out can damage the clip badly and cause it to break off in the tranny or could even cause the clip to bend enough that it won't come out at all.
Gord Galloway
Alberta Race Car Association Vice President
Honda CRXsi IT2 #32
