Tear it apart.
Four (4) or less jacking points may be added for the purpose of safely raising or lowering a vehicle. Jacking points may be added with either a plate or tube. If using a plate, it must attach to the floorboard of a vehicle by welding and/or the use of bolts. The plate may be constructed out of material no greater than 1/4" thick with a maximum size of 64 square inches and no one side longer than 10 inches in length. Jacking points constructed out of a tube must use the same diameter and thickness of the vehicles roll cage and may be no longer than 12 inches in length per jacking point. Tubes may only be attached and welded to the vehicles roll cage. A hole the same size as the tube may be cut in the chasis to facilitate installation. Jacking points must be able to raise and lower a vehicle with the use of a floor jack.
Mark B. - Dallas, TX
#76 RX-7 2nd Gen
SCCA EP
Former ITS, ITE, NASA PT
