We are running a 1985-6 VW golf 1.8 V in ITB, . Yesterday at Road America, the car started out running strange (down on power) then all of a sudden in the front strait the it ran, OK, then it would sputter in the corners but cleaned out in the straights, This morning put in Bosch 4310 Plugs ( the standard heat range) , it appeared to run but still missed, then after sitting would not even run enough to get the car moving.. It sputters feels like a missfire and will not build RPM (like running rich). Would barley make it on the trailer If we bump timing to like 20- 30 degrees it gets better.
With CIS injection, stock ignition,
Timing belt is tight and appeard not to have "slipped a tooth". Replaced plugs, wires, cap rotor, knock sensor, coil, igintion module, ( complete distributor) all this was swapped from a running car.
Did we go the wrong route and its fuel?
JimTripleHelixRacing
