Well, it is an absolute fact that a wider rim will increase the weight, leading to worse performance.
It is also obviously true that there is no change the rules on max tire size/width.
So, it comes down to sidewall angle.
Let's see what we are dealing w/:
Let's use 225/50, since that is what a lot of the B racers are running.
6" wheel plus 2 * .5" lip = 7"
7" wheel plus 2 * .5" lip = 8"
The section width for a Hoosier r6 225/50/14 is 9.8", giving:
6" rim: 9.8 - 7 = 2.8 or 1.4" per side
7" rim: 9.8 - 8 = 1.8 or 0.9" per side
(.5" difference, as would be expected)
Since the tire is a "50", and the section width is 9.8", that means the section height is 4.9". Thus the sidewall angles are:
6" rim sidewall angle = arctan(1.4/4.9) = 15.6 degrees
7" rim sidewall angle = arctan(0.9/4.9) = 10.4 degrees
I'll see if there are any studies on what a difference between 10 and 15 degrees sidewall angle causes in a performance application.
However, it also should be noted to any impact is very much tire specific, since the strength of a sidewall varies quite a bit per tire....with racing tires being very much on the high (stiff) end of the spectrum, and thus have less impact from sidewall angle differences.
