Results 1 to 10 of 10
Thread: neon rad
    Mar 2007
    134
    Has there been a thread on here about Neon rads? I am using the larger, stock rad, but I think more is an order. Any suggestions or directions to a previous discussion?
    Jim Barnsley, Streetwise Service
    WCMA IT2 Neon Twincam
    2009/2010 Regional and Alberta IT2 Champion
    2009 Regional Overall Champion. Second this year, dammit.
    Purcellville, VA USA
    902
    I haven't found a need for anything other than the stock radiator. Perhaps you have other cooling issues?
    Chris "The Cat Killer" Childs
    Angry Sheep Motorsports
    810 417 7777
    angrysheepmotorsports.com
    IT,SM,SS,Touring, and Super Touring
    Jun 2007
    169
    Check out my thread here:
    http://forums.neons.org/viewtopic.php?t=294925
    -Jeff S
    '07 Mid-Am ITA Champion
    '07 St.Louis Region Driver of the Year
    www.plainoldgas.com
    Honda S2000 for ITR in the works
    902
    What Controller are you running that is pulling timming at over 200? Sorry, but I haven't had that problem? I am not saying that keeping the engine running cooler isn't a good thing. I just don't have issues with running much hotter than 200 with a stock radiator.
    810 417 7777
    Feb 2006
    Daytona Beach, FL
    98
    I'm not sure which gauge to believe on my car. My water temp gauge does reach 220 under race conditions here in Florida but the factory gauge is always right in the middle so I have not worried about it too much. I did run some water wetter last time but did not seem to change much. I am running the Mopar Performance computer in mine.
    Darryl Pritchett
    ITA #92 Dodge Neon
    2008 SE DP Champion
    2010 CFL Region ITA Champion
    Mar 2007
    134
    My first race with the car, I had no trouble at all with temp, but at the second, it was climbing, and pushing water out the overflow after 8 laps. I think I must have a head or gasket issue, just the way it acts. I figured with a fresh head and good multi layer steel gasket I should have been ok, so I want lots of capacity for after I repair it again.
    I am running the mopar performance ECU, on a twincam, new stock rad. That big aluminum thing looks nice. Maybe a bit heavier, but the car slows down shifting at 4500 rpm too.
    I also have to get a real gauge- that stock cold/normal/shut it off now thing irks me.
    Feb 2004
    st. louis mo.
    433
    One thing I learned the hard way( twice actually) is that a water temp guage needs to be supplimented by a water pressure guage also....I had a water loss issue that the temp guage did'nt show....ie it never read over 225 each time.... I learned that it can't read what's not there ....mike.
    902
    Good point Mike. I too have used water presure warning lamps
    810 417 7777
    Feb 2004
    st. louis mo.
    433
    double post...sorry....mike.
    Nov 2005
    86
    We just ran at Lime Rock this past weekend and were running a bit hot with the new setup. I have to take a look at it and figure out what was going on.
    We did see a really nice Ron Davis radiator in Walts ITA neon. I'll have to look into that more. He unfortunately didn't run as he lost an alternator. I offered one up to him but he decided to just pack it up.
    Greg Meindl
    #74 Dodge Neon ACR ITA
    #75 Dodge Neon ACR ITA
    #84 Dodge Neon ACR ITA Enduro
    #74 1965 Ford Mustang Coupe TA SVRA
    #74 Pontiac Firebird Formula T2 Sold on its way to Arizona !
    #74 Dodge SRT-4 T2 Sold residing in Indiana
