Results 1 to 7 of 7
Thread: Wheel and Rim
    May 2007
    49
    Hi I have a question, I have a chance to pick up a set of 16 rims for my Mustang, the problem is I run a set of 14's on it, 205/55/14 as a matter of fact. I was wondering what I would need to do to use these rims and get a tire thats not to far off of the circum. I have now or should I just leave em alone. Thanks for the info
    Kevin Beck
    StangIT Racing
    Claremore, OK
    Mar 2002
    Black Rock, Ct
    9,594
    Go to the tire companies websites, (Hoosier, et al.) and see whats available, Compare outer diameter for compatibility. Obviously, if it's larger, you'll need to change gearing, AND, you will raise your ride height. Now, you might be able to lower it back down, but you'll lose some suspension travel. Maybe an issue, maybe not.
    Secondly, will the new combination help or hurt acceleration and braking? You want unsprung weight to be low, especially if it's rotating. Look at your current wheel and tire weights, then compare through the charts what the new combination would be. More is bad. The same is OK, IF the diameter is the same.
    Finally (well, there's more actually, LOL) the new combo will result in a different spring rate, most likely, as the sidewall will be stiffer than it was before. (Assuming you maintain diameter). So springs and dampers might need tuning.
    All of this assumes you've optimized for your current setup.
    IT-7 #57 RX-7 race car
    BMW 2003 M3 cab, sun car.
    GMC Sierra Tow Vehicle
    lateapex911(at)gmail(dot)com
    Buffalo, New York
    2,942
    Neither 13 nor 14(s) receive that great tire manufacturer support in IT any longer. If you were opting to go for a change, I would consider 15 inch rims.
    Apr 2003
    Sterling, VA
    734
    I may be miss reading this, but I think we need more information. You currently run 14 inch rims, correct? You have a chance to pick up a quantity of 16 rims? What size are these new rims?
    Spanky | #73 ITA 1990 Honda Civic WDCR SOLD | #73 ITA 1995 Honda Civic WDCR in progress |
    ** Sponsored by J&L Automotive (703) 327-5239 | Engineered Services, Inc. http://www.EngineeredServices.com **
    Isaac Rules | Build Pictures
    Jun 2001
    Milwaukee, WI
    1,193
    I'm really disappointed I have to be the one to bring this up!
    Did the mustang come from the factory with 16s? If not, (and assuming you are IT racing, based on your sig) you cannot run them in IT. The largest you could run is 15.
    "Most people have the will to win, few have the will to prepare to win.” - Bobby Knight
    Bill
    Planet 6 Racing
    Apr 2003
    Sterling, VA
    734
    That is why I think he said a set of 16 (count) rims. I had the same first thought you did.
    May 2007
    49
    Thanks Guys your where right, I made a little error in reading the GCR and the 16's are out. Thanks for the info it would of cost me and it would have been for nothing, sure is tough to find 15's for this car
    Kevin Beck
    StangIT Racing
    Claremore, OK
