i'm slowly building a car to scca its spec.
1991 240sx.
it's coming along fine, just need the window net brackets welded, fire system, and battery/alt switch installed and i should be ok.
i had a few questions to all you other 91-94 owners. what were you able to remove as far as weight goes, what was your competition weight, your own weight and did you end up having to add ballast?
