Results 1 to 5 of 5
Thread: Fuel test port valve location
    Jan 2003
    New York, NY
    190
    We are building an S2 for ITR. Any suggestions where to hook up the fuel test port valve?
    Thanks...Anthony
    Anthony
    STU Porsche 944T
    ITB Volvo 142 (in the making)
    Nov 2004
    Ligonier, PA, USA
    1,676
    Thanks...Anthony [/b]
    www.fuelports.com
    Paul will fix you up
    Jan 2003
    New York, NY
    190
    Paul will fix you up[/b]
    I spoke with Paul last year. He was not terribly familiar with the 944 and, as I recall, I did not like his suggestion. I'm trying to find out what others have done.
    Anthony
    STU Porsche 944T
    Nov 2004
    statesville, NC USA
    167
    We drilled and tapped our 8v in the front of the fuel rail for the fuel port. There was a capped fitting there from the factory. I think on your 16v it may be on the side of the fuel rail(?). Bring a length of hose with you to the track that fits on the fuel port to keep from spilling any fuel while taking a sample.
    1984 Porsche 944 ITS #54
    Aug 2003
    Hendersonville, NC
    174
    I replaced the fuel lines with Earls. Before the line gets to the fuel rail I used the fuel test port from Pegasus.
    http://www.pegasusautoracing.com/productde....asp?RecId=3447
    You also need the fittings recommended. It goes in very easily and takes no real-estate.
    I also zip-tied a piece of 3/8" rubber hose to the roll cage so it can be whipped out and connected to this port. The tech guys loved that!
    timo
