i currently have the car placed in IT2 which is your ITB, any ideas>?
these are the specs on both the 3 door and 4 door , 4 door is longer and weighs more ,
My Webpage
My Webpage
If it's not listed in the ITCS (SCCA IT Comp. Specs.) portion of the General Class Rules - and I don't think it is - you have to request that it be added.
GCR is at http://www.scca.com/Club/index.asp?reference=gcr
...and links to the rule change process and online form are there as well.
As Kirk said, if it's not listed you'll need to request to have it classed. If this is the case, you could probably go by the 3 door weight while you're working on getting the car classed. If it's a 4 door LS/GS (non-vtec) car then it'd be an ITA car but if it's a 4 door GSR (vtec) car it's ITS.
Christian
edit:
I just noticed the "ls" in your post title... ITA and probably at the same weight as the 3 door LS
