Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Hoosier wets vs. dirt Stockers
    Oct 2002
    newington, ct
    4,182
    On the 4th of July at Lime Rock Park, we had fairly light rain, and there were no puddles. (It was far from pouring rain.) The temperature was fairly mild and not what I'd consider to be cold. I thought for sure the tire of choice would be the Hoosier wet tires, but several people after the races mentioned the tire to have that day was the Dirt Stockers. I was surprised by this, and wonder if that was really true? If it is, when would the Hoosier wet tires be the tire of choice?
    Dave Gran
    Royal Oak, MI, USA
    1,599
    I've heard that the Wets are better in a true rain situation with standing water, in that the proper grooving does a better job of clearing the water out of the way; by comparison, the Dirt Stockers are just a soft sticky tire with some grooving, and still will hydroplane, just not as bad as R6's.
    Can't say myself; while I have run R6's and Dirt Stockers, the sponsor hasn't ponied up any tire money for rains...
    Vaughan Scott
    Detroit Region #280052
    '79 924 #77 ITB
    #65 Hidari Firefly P2
    www.vaughanscott.com
    Mar 2002
    Black Rock, Ct
    9,594
    I think the Dirt Stockers are faster in most wet conditions because of the soft compound.
    But...if it dries mid race, you're screwed. Only actual back to back testing would really answer the question.
    IT-7 #57 RX-7 race car
    BMW 2003 M3 cab, sun car.
    GMC Sierra Tow Vehicle
    lateapex911(at)gmail(dot)com
    May 2003
    Colchester, CT, USA
    2,120
    Yes, the Dirt Stockers seemed to be the tire of choice. As Jake said, they get heated up and good and sticky....
    Anyone know what the ITS BMWs were on?
    Jeff L
    ITA Miata
    2010 NARRC Champion
    2007 NERRC Championship, 2nd place
    2008 NARRC Championship, 2nd place
    2009 NARRC Championship, 2nd place
    Nov 2004
    CT
    982
    I am 90% sure they were on Wets as they don't make dirt stockers in their sizes.
    Jeremy Billiel
    Apr 2001
    NH, US
    3,821
    We went to a "Rain" test day at Lime Rock last year and put 3-4 hours on a car simply doing car set-up. We made pit stops changed from wets to dirt stockers and back again. lap times were very similar. I don't think that you could actually get the true benefits of one tire vs. the other without a DL1 or simmilar, but here is what we decided...
    From last years NARRC Runoffs posts:
    "Tuesday Testing:
    We came down for the test day and Stephen was able to turn 1:19’s and 1:20’s consistently on the cold open wet track, so we new that he would do well in the rain. I had a slipping clutch due to what we thought was a bad rear main seal (I tried fixing oil leaks and apparently got more). I was still able to turn consistent 1:22’s without using 4th gear at all, so we also new that with a fixed car I should be able to get into the 1:19’s along with Stephen. During testing we also tested several setups and found out some interesting stuff… New Hoosier rains were about 1 second a lap faster than Dirt Stockers with better grip under braking and acceleration, however the Dirt Stockers were more comfortable with better grip in the actual turns. Also changing camber settings really had no effect on how the car handled or felt nor did it change what we were able to get for tire temperatures/pressures.
    I know what my wish setup is and it isn't what I have... but I can say that I did kick some ass last year on the Dirt Stockers
    Raymond "Sorry to kill the ego's but its all about the driver on this one" Blethen
    RST Performance Racing
    www.rstperformance.com
    Oct 2004
    Northeast
    7,031
    We grabbed a few temps over the weekend and the Dirts were almost 40 deg warmer than the Wets coming off the track.
    Andy Bettencourt
    New England Region 188967
    Oct 2002
    newington, ct
    4,182
    Raymond "Sorry to kill the ego's but its all about the driver on this one" Blethen [/b]
    Just to clarify, I never said that wasn't the case with the Jim beating me. That aside,there were still several people talking about the two different tires related to several different cars & classes. I had always thought that the dirt stockers were the tire to have in a heavy down pour, but the Hoosier wets were the tire for wet but not heavy rain conditions.
    Dave Gran
    Mar 2001
    Connecticut
    7,381
    Dirt Stockers are the choice right up until you start to overheat them (i.e., anything but a completely wet track). Then you go to...
    Wets, right up to the point you start to overheat them (e.g., fully dry track), then you go to...
    A6 compound, right up until you start to overheat them (e.g., anything but a cold dry track surface), then you go to...
    R6 compound. Right up until you suck.
    The limiting factor is temperature, plain and simple.
    Problem is, that first choice soon won't be a choice; as far as I can tell, Hoosier has discontinued the Dirt Stocker. Ergo, no point in getting all worked up about that tire, because as soon as the existing tires get all hardened up from sitting in the sun on these open trailer tire racks, the D.O.T Wet will be the tire to have...
    Apr 2005
    Baton Rouge, La., U.S.A.
    913
    I've heard the same as what Greg wrote. You can still find some Dirt Stockers in old stock situations, but it's rare. I've been told, by some Hoosier guys, that if the track is virtually flooded, the Dirt Stockers are the best, but if it's regular old rainy weather, the rains are the thing as they will stay reliable longer.
    However, if you're like me, I used my Dirt Stockers once...moved me right up the grid in the middle of blaster cars. Trouble was, it was dry for the race, and I was a mobile chicane for a lap or two. The rest of the time the tires sat on my trailer until the tread was ready to crubble, and the carcass was two hard to drive a nail through them.
    My new rain tires are covered and brought inside after every race weekend.
    Chris Harris
    ITC Honda Civic
    Apr 2001
    NH, US
    3,821
    Dave-
    I wasn't picking on you You drove one hell of a race, and you were smart As we both know Jims car is fast and handles very very well.
    Andy, thanks for the data, I have a few questions not to critisize but to learn, I love the rain and want to do better... Anyway, did you get the temps from your Miata's? Why did you choose different tires? Was it the same or different drivers? What were the lap times? If it was the same driver (running in two groups) was the finish in the rain vs a sprinkle?
    I am just curiouse as we get our front tires very very hot and had no real difference from one tire and the other in reguards to tire temp. That was with the same driver, same conditions, similar lap times, and in back to back sessions.
    Raymond
    Aug 2005
    1,717
    What is this rain you speak of? On the fourth we got up to 112F but it truly was a dry heat, with a relative humidity of 1% My friend uses his dirt-stockers to hold his sun shade canopy down. I suspose that's why no races are on our calender untill September.
    STU BMW Z3 2.5liter
    Oct 2004
    Northeast
    7,031
    This was later in the day in the wet drizzle. Two FWD cars, one with DS and one with Wets. I chose the Wets because it is supposed to be their latest and greatest...and I am sure they are better in some ways. The DS weren't available when I got these 18 months ago.
    Bottom line, exploit you advantages where you can! Joe and Rick would have whipped me even if I had had Dirts. They were on.
    Andy Bettencourt
    Oct 2002
    newington, ct
    4,182
    The 7/4 LRP lap times were just recently posted and I found the results to be very interesting. I took a look at the 1st place ITB car's lap times (James Macmahon) who was on dirt stockers vs. my times on Hoosier wets. After looking at it more closely while knowing the background of the race dynamics, it appears the tire choice may have been a wash like Ray stated. A couple of laps into the race, Jim caught me and I decided not to push so hard I took myself out of the race. Once he passed me (around lap 8), I was able to learn quite a bit from him and started pushing things harder but attempting not to do anything dumb.
    I realize that Jim probably wasn't pushing 10/10ths, but I was surprised to see that my fastest time was over 1/2 second faster than his. This goes right back to what Ray said, "its all about the driver" (meaning Jim was the man that day!). Maybe it's time for me to move out to Seattle so I can get more rain experience. There are some 185s dirt stockers for sale at a reduced price ($100 each) that I was tempted to buy, but it looks like I should spend my money in other places.
    Wet, but far from pouring rain conditions (lap times)
    Dave Gran
  15. #15
    Jun 2005
    Kansas
    532
    A couple of points I haven't seen mentioned WRT to the nearly extinct Dirt Stockers vs the other "wets".
    - The DS is a totally different construction (bias ply) with totally different feedback. My experience with the DS is that it gives you less overall grip than some of the newer rubber on a wet (but not flooded) track. However, the DS seems to give you about a mile and a half of warning before it lets go. It is very easy to drive at the edge of adhesion, but that edge will probably not be as fast as some other tires under the same conditions.
    - If you look at the footprint of the DS vs the R6 in a given size, you'll typically find about an inch less width, and you also have to subract all that area where there is no rubber... the grooves. Bottom line is that you're probably running on at least 25-30% less rubber with the DS. Less rubber equals less grip - again, we're assuming a wet, but not flooded, track. When it really rains though, size for size, the narrower DS has an inherent anti-hydroplane advantage, tread patterns notwithstanding.
    Gary Learned
    MiDiv
    Volvo 142E
  16. #16
    Oct 2004
    Northeast
    7,031
    For me, its all about compound. The DS seems to heat up MUCH quicker. If you have a cool day with enough water to keep them cool but not enough to hydroplane, I think they are a superior tire. Typically the amount of grip available is not enough to notice a significant charateristic difference.
    Andy Bettencourt
  17. #17
    Apr 2001
    NH, US
    3,821
    I think we need an autocross wet tire to be made
    Raymond
  18. #18
    Jan 2007
    16
    Perfect example was last weekend at Barber:
    The Saturday race started maybe 1/2 wet, with a light sprinkle. I was on RA1's, and we did like an "intermediate" setup. I went from 6th to 2nd by the end of lap one (20th to 7th overall), and was on the leaders ass by lap two. Then it started pouring, and the RA1's went to slop. I just worked on maintaining position, and finished 2nd, like 10 seconds back. The winner had Dirt Stockers on, but I clocked fast lap on lap two. Seems that Greg is right, the stockers are for total rain conditions, then move away from that with degrees of dry track.
    Thomas Lyman
    2007 SARRC ITA Champion
    #06 ITA Acura Integra
  19. #19
    Apr 2005
    913
    Who started this thread, anyway?! I hadn't touched my rains in three years...this discussion starts, and all of a sudden I run into a rain race with no crew. I didn't know I could change tires so many times in one weekend and still make grid! All I needed was for someone to start a thread about brakes and those would've gone away worse than they did!
    Not that I'm superstitious or anything
    Chris Harris
    ITC Honda Civic
  20. #20
    Oct 2002
    newington, ct
    4,182
    Great idea! A "How to manage brakes when they've run out of material" thread.
    Dave Gran
