Ray, I had the exact same thing with my Rabbit. We had cleaned it of using staring fluid before we installed the tranny with new seals. Even with that cleaning it took 5-6 laps before the clutch started grabbing like it should. Once it burned off the little bit of residual oils it worked fine. The Prod. cars I crew for routinely re-use clutch plates that have had oil on them.
Jon
