Results 1 to 6 of 6
Thread: Camber Plates
    Feb 2006
    Daytona Beach, FL
    98
    Okay this is a stupid question but I just received Camber Plates and Coil overs from ground control, with no instructions. Does the plate on the camber plate go underneath the strut tower or on top the strut tower. It appears like if it is on the top it is really going to lower the car alot.
    Oh ya its on a Dodge Neon.
    Darryl Pritchett
    ITA #92 Dodge Neon
    2008 SE DP Champion
    2010 CFL Region ITA Champion
    Mar 2001
    Connecticut
    7,381
    I've yet to see a GC plate that goes underneath; they are designed to go on top.
    I'm not saying it's not possible, but I've never seen one otherwise... - GA
    Oct 2004
    Enfield, CT, USA
    488
    Greg,
    The set of camber plates for my charger are installed underneath the towers so it is possible. They are a universal kit since for some reason no one made a kit for my car but it made more sense to provide additional bearing area during compression rather than relying on bolt tension.
    Also, it may be important to mention that the reports on the neons suggest it doesn't respond well to excessive lowering. Supposedly the geometry doesn't respond well and there is not a lot to be done that is IT legal. That is just secondhand information though so there are some others with first hand development experience that can hopefully chime in. What about it Chris, any hints?
    Of course with the right spring choice you should be able to allow for however you decide to install the plates.
    ~Matt Rowe
    ITA Dodge Neon
    NEDiv
    Sep 2004
    atl,ga
    88
    I have ground control camber plates on a street neon and they are under the strut tower.
    The cat-killer is flying back from Miller today, sure he will answer soon also.
    David just call ground control and ask them they are very nice and always helpful.
    Hey Matt
    k
    Purcellville, VA USA
    902
    Hey Matt
    k
    My brain is still fuzzy after this last weekend...
    The Camber Plates do mount under the strut tower.
    When you lower the Neon too much the roll moment gets to out of control. You end up not being able to control roll even with very high spring rates. This is bad!! Try to keep it about 5.5" at the rocker on the left front with about 1.5" of rake.
    Chris "The Cat Killer" Childs
    Angry Sheep Motorsports
    810 417 7777
    angrysheepmotorsports.com
    IT,SM,SS,Touring, and Super Touring
    Nov 2005
    86
    Just ordered up the camber plates. Mark at Ground Control was very helpful and got back to me asap. Interesting that they don't have them on the shelf but actually make them up as orders come in. He said they have a 48 hour turn around time so thats great.
    Greg Meindl
    #74 Dodge Neon ACR ITA
    #75 Dodge Neon ACR ITA
    #84 Dodge Neon ACR ITA Enduro
    #74 1965 Ford Mustang Coupe TA SVRA
    #74 Pontiac Firebird Formula T2 Sold on its way to Arizona !
    #74 Dodge SRT-4 T2 Sold residing in Indiana
