Results 1 to 3 of 3
Thread: Obscure Nikki carb question (RX-3 version)
    33
    I am working on an EP RX-3 that has what I believe is the original Nikki carb with primaries bored to match secondaries.
    Accelerator pump shot was very weak. Diaphragm is fine, adjusted all for full pump, and still just a dribble.
    The check ball setup on this carb is different from the one on the RX-7, and I need to know how it is supposed to go. On the later Nikki there is a check ball with a brass weight and a plug that go down toward the accel pump. On this carb there is only a ball, and the plug has a long needle type extension on it. Is that all there should be?
    Can anyone also verify that there should be a check ball but no weight under the pump squirter on this carb?
    Any other suggestions short of a teardown/rebuild? I have verified that fuel is flowing fine through all the passages, squirters are clean. It just doesn't seem to squirt well when the pump is actuated, and I think it's getting pumped back into the bowl rather than through the squirters.
    {OR - does anyone have the parts catalog or shop manual page with an exploded view of the RX-3 Nikki that they can scan or copy for me? I'll pay for this service!}
    Thanks,
    Steven
    St. Louis, MO
    1,215
    Steven,
    I'm 99.9% certain I have an RX-3 carb out in the shop that I bought off of ebay a couple of years back. If you want to swing by and grab it give me a call.
    Scott Rhea
    Izzy's Custom Cages
    Performance Driven LLC
    Neon Racing Springs
    Mar 2006
    54
    There needs to be two checks balls on that carb under the squirters
