Results 1 to 6 of 6
Thread: Power steering overflow (for a Neon)
    Oct 2002
    newington, ct
    4,182
    This past weekend at a HPDE with our Neon, it looks like the power steering reservoir is over-flowing a little bit only while out on the track. I've heard of this happening with other vehicle makes, but am not sure how best to resolve the issue. I checked the fluid level, and it appears it is where it should be. Is this something that is common with Neons? Any ideas on how to resolve it? I suppose I could start with replacing the rubber ring/seal.
    Dave Gran
    Run it at minimum or slightly below.
    Put a sock on it.
    Purcellville, VA USA
    902
    Put a sock on it.
    Greg,
    You hit the nail on the head!
    Chris "The Cat Killer" Childs
    Angry Sheep Motorsports
    810 417 7777
    angrysheepmotorsports.com
    Oct 2002
    newington, ct
    4,182
    I'll even use a clean one. LOL
    Chris,
    Just curious - is this fairly normal on Neons?
    Dave Gran
    902
    Chris,
    Yes, I don't run the sock, just because I don't like the mess. I just wipe it off after each session. If your car is a DOHC the problem is worse due to RPM. The DOHC can rev a bit higher.
    810 417 7777
    Feb 2004
    st. louis mo.
    433
    Yes its normal.....I used to run red line p/s fluid and do run it a little low...that should fix you up !!...mdg.
