Results 1 to 6 of 6
Thread: Engine removal
    Aug 2006
    11
    I am going to be removing the engine from the 944S in the next few weeks - All the information I have states it has to come out from the bottom of the vehicle - Seeing as I do not have a lift in the garage this could be difficult - Can engine come out from the top? Any advice will be appreciated - Thanks in advance
    Ray Blethen III (Sr.)
    RST Performance Racing
    #50 AS 1994 Mustang
    #49 ITS 1987 Porsche 944S
    Royal Oak, MI, USA
    1,599
    I'm pretty sure that it can... might just be a little more work than out the bottom. I hope you're not just relying on the Haynes manual for this R+R?
    Vaughan Scott
    Detroit Region #280052
    '79 924 #77 ITB
    #65 Hidari Firefly P2
    www.vaughanscott.com
    The engine can come out the top. A few more things need to be done though. The clutch and bellhousing should be disconnected and the radiator should be removed. The engine needs to come up and forward to clear.
    Dick Gagliardi
    LoopRacing Scirocco II
    H prod, Chicago Region SCCA
    Aug 2006
    11
    Thanks for the info - I have the 944 Porsche manual on a disc I got a couple years ago for the S2 carbriolet - I did check the Haynes manual which I have little faith in and it said out bottom - Radiator needs to come out any way so might as well try out the top -Thanks again - hope to be on track mid June
    #50 AS 1994 Mustang
    Atlanta, Ga
    631
    I could be mistaken in this, if so, somebody correct me.
    First take out the transmission. Once its out of the way, you'll need to pull the driveshaft tube back
    in order to remove the clutch and bellhousing. You'll also have to puzzle the driveshaft tube back by
    twisting it so that it can clear some sections in the tunnel. It can be done on a car thats just up on
    jackstands, but its an accomplishment. And remove the radiator.
    The factory manual shows a removal from below procedure, but not everyone has a lift, so take it out
    the top.
    Tom
    Nov 2004
    statesville, NC USA
    167
    Some good info in the shop manual section here: http://www.clarks-garage.com/
    We found it easiest to use jackstands and come out the bottom, even though we have a lift and a cherry picker. I think most that prefer to take it out the top don't want to remove the crossmember which requires you to recheck your front suspension settings.
    1984 Porsche 944 ITS #54
