Results 1 to 6 of 6
Thread: Sorry, another door bar question
    Mar 2005
    Oxford, MI
    20
    I'm sorry, but I try keep up with the posts but just want to clarify that what I'm about to do will be legal. As we all know it says that NASCAR style or "X" style bars are permitted, not mandatory. So if I weld two bars that are horizontal to the ground that connect the front and main hoop, I should be okay, correct? That way I have the two required door bars. Please steer me right if this is not the case.
    Also, if I did do the "X" style on one side, do they have to bisect each other or can the two pass by each other close enough that I can weld them together without cutting one in half?
    Let me know if that makes sense.
    Thanks in advance.
    Mike
    Mike Ofiara-Detroit Region
    VW GTI #28 ITS
    Sep 2001
    hampden,ma.usa
    3,083
    as long as you have a minimum of 2 bars you are okay and you can weld them together if you want.
    dick patullo
    ner scca IT7 Rx7
    Mar 2002
    Black Rock, Ct
    9,594
    Yes, the requiremnts are rather loose on this, so you can actually create a "NASCAR" setup that isn't what you see in Nextel Cup. All in all, it's a good rule.
    IT-7 #57 RX-7 race car
    BMW 2003 M3 cab, sun car.
    GMC Sierra Tow Vehicle
    lateapex911(at)gmail(dot)com
    Mar 2005
    Oxford, MI
    20
    Great, really appreciate the help guys.
    VW GTI #28 ITS
    Nov 2003
    Madison, MS
    132
    This is a very timely thread for me too, since I am about to redo my door bars this week. I have a related question: I have to add a second bar to the passenger side. As I read the rules, I can gut the passenger door if I run the bars into the door. Do both bars need to protrude into the door? My plan is to leave the existing bar in place and add a second one below it that extends slightly into the door. Is this legal?
    Mar 2002
    Black Rock, Ct
    9,594
    Yes, IIRC, the definition of "Nascar" bars is rather loose. Reread it to be sure of course. (And there are some who feel that keeping the bar a bit away from the door allows any impacts to produce lower G-loads, as opposed to pushing the bar right up to the door skin/internal door bar)
