Results 1 to 3 of 3
Thread: ITA CRX Spring Question
    Oct 2006
    12
    1990 ITA Crx with 500F and 700R eibachs,koni adjustables. Car is oversteering a bit. I know this NOT a usual problem with front wheel drive, hence the reason I need help. I have tried shock setting, tire pressure and camber settings. I have stock front/rear sway bars, 15x7 205/50-15 V710's all around. Car is 2250 lbs. Should I maybe go up 100lbs. with front springs or go 100lbs. down in rear? Any help is appreciated.....Thank you ........Jeremy
    Oct 2005
    1
    Id go down with the rear springs. they seem a bit stiff for such a small and light car. An easy fix may be to just swap your front and rear springs and see how the car acts. That might fix your oversteer problem. Also you may want to mess with your rear toe settings. If you dont mind, maybe post up your alignment settings and Ill check them out.
    -David
    Jun 2001
    Warwick, New York
    941
    You don't have enough rear camber. I found that the car needs a lot of rear camber to eliminate the oversteer, and I think the sprint setting are fine.
    Tom Blaney
