Results 1 to 18 of 18
Thread: Flywheel material ?
    Apr 2006
    51
    Can an aluminum flywheel be used? IF I reminber right the old GCR said "made of same material."
    Here is what the 07 GCR states.
    "m. Any clutch disc and pressure plate of stock diameter may be used, provided that they shall be bolted directly to an unmodified stock flywheel. Balancing of the flywheel/clutch/pressure plate assembly is permitted. Lightening of the flywheel beyond the minimum material removal necessary to balance is prohibited. The addition of an external scattershield per GCR 9.3.39., is permitted and recommended."
    Aug 2005
    1,717
    How many cars come with Aluminum flywheels??
    Looks like you need an unmodified stock flywheel to me.
    Jame
    STU BMW Z3 2.5liter
    Wauwatosa, WI, USA
    2,658
    m33mcg, adding to what James said remember please. If it (the rules) don't say ya can, ya can't.
    Mar 2002
    Black Rock, Ct
    9,594
    If the car came stock...from the factory...with an aluminium (british pronounciation, please) flywheel, tyou are a lucky guy.. If not, then it's steel for you.
    IT-7 #57 RX-7 race car
    BMW 2003 M3 cab, sun car.
    GMC Sierra Tow Vehicle
    lateapex911(at)gmail(dot)com
    Aug 2005
    1,717
    Al-U-Miny-um
    Jake,
    Do you say Vit-a-min's or Moly-be-den-um?? Please pass the Pork scratchings and HP sauce
    James
    STU BMW Z3 2.5liter
    Apr 2006
    51
    Thanks for the help, I thought I found a few more ponies in the new wording.
    Feb 2003
    1,106
    well it does say
    [qoute]"m. Any clutch disc and pressure plate of stock diameter may be used, provided that they shall be bolted directly to an unmodified stock flywheel. [/quote]
    and not ..... the unmodified stock flywheel
    just kidding
    Wauwatosa, WI, USA
    2,658
    Keeping in mind that the word "stock" is not in the GCR glossary.
    Oct 2003
    Greensboro, NC
    517
    "clearing my throat" ahhhmmm.... how much material does one have to remove in order to "balance" the flywheel?
    ... exit stage right!
    hoop
    hoop
    Greensboro, NC
    STL Newbie
    Wauwatosa, WI, USA
    2,658
    Rule:
    ***Lightening of the flywheel beyond the minimum material removal necessary to balance is prohibited.***
    ***"clearing my throat" ahhhmmm.... how much material does one have to remove in order to "balance" the flywheel?***
    hoop, it will be obvious to the most casual observer that knows anything about balancing a flywheel what lightening beyond what's necessary looks like.
    Have Fun
    Oct 2005
    114
    There are cars running IT that have (LEGAL) aluminum pressure plates and Tilton discs.
    Wauwatosa, WI, USA
    2,658
    ***There are cars running IT that have (LEGAL) aluminum pressure plates and Tilton discs.****
    Rule:
    Any clutch disc and pressure plate of stock diameter may be used.
    Yes there are because the rule allows any weight PP & DISC of the stock diameter.
    Just for info the rule has been closed for Spec Miata for year 2007 & beyond but the Miata can still run lightend stuff in ITA.
    Have Fun
    Buffalo, New York
    2,942
    At least 5 lbs. for a start.
    Oct 2004
    Northeast
    7,031
    Balancing is a techique. If you 'turn' a flywheel - like you would to resurface brake rotors, you are lightening illegally. No questions asked. When you look at a professionally balanced flywheel, you will see that there is no comparision.
    Andy Bettencourt
    New England Region 188967
  15. #15
    Oct 2003
    Greensboro, NC
    517
    i'm glad several of you found humor in my coment about removing material... but seriously, never having had a flywheel "balanced" what is the difference, between that and turning or resurfacing?
    hoop
    Greensboro, NC
    STL Newbie
  16. #16
    Mar 2002
    Black Rock, Ct
    9,594
    The flywheels I have seen have areas that get drilled out to balance.
  17. #17
    Oct 2004
    Northeast
    7,031
    The flywheels I have seen have areas that get drilled out to balance. [/b]
    Correct sir. This is a picture of a HORRIBLY out of balance flywheel that has been balanced.
    Andy Bettencourt
  18. #18
    Sep 2003
    Livonia,NY,USA
    77
    From that picture, it looks like it first got drilled to make it unbalanced so they could take another 5 pounds out to make it right.
    Kinda like giving your kid a haircut. By the time you fix all your mistakes, he's got a GI cut.
    Dave Ciufo
    Livonia, NY
    ITS 240Z #34
    SM #34
