Maybe this has been discussed before, and maybe it's time to touch on this subject again as consumer electronics goes in and out of style so fast. We have a Panasonic PV-250GS mini-DV camera that I used on my first couple of races on an I/O port mount. While using it on my second race I started having vibration problems, so I shortened up the mount but I've still had an issue with the narrow field of view. So while at Best Buy, I start looking for a wide angle lens, which they have, it doesn't fit the larger lenses on the Panasonic. I'd considered buying a second camera just for the car, one that was less expensive than the Panasonic, because of the shortened life in harsh vibrational environments.
So I went with a Sony HDD camera, thinking that with no moving parts it'd be way better than the mini-DV's. Well, I was wrong, the hard drive in these camerea's isn't solid-state like I'd though it would be, I found out last weekend when the camera would shut off within 50ft of leaving the pit spot.
So I took the Sony back and exchanged it for a Samsung SC-X210L sports camcorder. This little wonder is about the size of an old analog cassette tape, I've had walkmans that were larger than this camera. It comes with a bullet/lipstick cam that has a lens wide enough to cover the whole windshield. Only issue is the microphone tends to get swampped out by noise. This time I've tested the camera well in advance of needing it, so I don't repeat my failure of last weekend to getting any video. My next project will be finding a way to mount the video unit in the car. Anyone else using this camera? Have you found a way to keep the sound from dropping out? Any other camera that's working well for you?
James
