Just finished my last event with my third engine.. (84 Scirocco IT the practice session went great! for the first time this year the car great in that session - good temp, fuel mixture and oil pressure. The gremlins returned in qualifying: I had pulled the radiator fan assembly since the ambient was so cool and temp seemed not to be an issue. 4 laps into the session the temp ran high, the overflow tank was blowing fluid which was hitting the tires.. I thought it was because I had taken the fan off so I reinstalled it for the race.
Didn't complete the first lap in the race -- overheated again and it sure reminded my of the first engine loss I had this season, I melted the pistons by running lean. I pulled off as the overflow tank was blowing fluid again. Diagnosing the first engine was tough because the ignition distribitor was going at the same the fuel pressure controller was failing, ugh. Brand new distributor on the car now. When I got the car home I hooked up the dwell meter to read the freq cycles (I had the car set very rich with the set screw, the freq was only at 15 to 20 cycles at idle if it even came on, the full throttle switch runs the freq cycles to 60). As it idled at 15 it would suddenly stutter and begin to run lean, either severly with the freq cycles going to 90 or mildly with the freq cycles jumping to 50 or 60 and then it would drop back to 15. I hooked up the fuel pressure gauge and it was locked on 51 lbs pressure the no matter how it leaned out. I did determine the fuel pressure controller was faulty on the first engine failure - replaced both it and the fuel distributor (both used) and the issue cleared up. I think I was running lean again which caused the overheating - it wasn't as severe as last time since I was running much richer at the fuel distributor this time. Do you think I had a second fuel pressure controller failure? twice in a season? anything I am missing on this? thanks I will look for a new controller this time. Any ideas on what else to check would be appreciated.
