We've exhausted ourselves over on the Mazda forum so I'm throwing this out here. I don't think it is really a Mazda-specific issue.
2nd gen. ITS RX-7, new battery + 300 amp booster, new rebuilt starter, new plug wires, 2 events on engine rebuild
This car has always turned over slowly but now it won't turn fast enough to even fire up. To eliminate any issues w/ kill switch, ignition, cables, etc., I unhooked the battery cables and ran a new battery cable from the + post to the + lug on the starter. I jumped a ground from the battery neg. to the starter case and applied 12v to the solenoid terminal. It still turned over too slow to start. I pulled a plug from each rotor and it was a little quicker but still not fast enough. Thinking the clutch might be stuck, I jacked the rear off the ground, put in 5th, put the clutch in, and cranked it - wheels not turning. Just to be sure I took the starter off this morning and checked it and it spins fine. Any ideas? I am at my wit's end.
Bill Denton
02 Audi TT225QC
95 Tahoe
Memphis
