Results 1 to 20 of 61
Thread: WHY IS MY 13B A SLOW TURNER?
    Rochester NY
    222
    Bill I used the same plugs in a much higher HP motor the was regulary taken to 9000+ RPM. Did you happen to see the blue and red RX7 at the ARRC? That's my old car and I built that motor 7 years ago and it is still going strong, all the time using the 10.5 plugs. I don't think the plugs are your problem.
    I would guess that when the motor was rebuilt the apex seal springs were not replaced and worked just fine at idle but at higher RPM they were too weak to hold the seal against the housing. Result is that the seal bangs around in there and eventually hammers itself to death. That old seal wasted your $30 plugs and most likely the housing too.
    You might want to think about a different engine builder. Sorry you had a crappy race.
    John Weisberg
    BERG Racing
    Rochester NY
    203-556-0427
    http://www.berg-racing.com/
    Floyds Knobs, IN
    1,093
    Since I was outed as the engine builder earlier in the thread I feel the need to rebuff your "guess". Quite simply it's wrong. Bill lost three engines this year. At least two to broken apex seals. This one was mine the other one wasn't. He has an issue other than bad spark plugs or old apex seal springs. IT engines don't break seals with regularity (shouldn't break them at all) without assistance from a major problem in the electronics. Be it ignition or injection. I'm leaning toward the former.
    Chris Ludwig
    GL Lakes Div
    www.ludwigmotorsports.com
