Results 1 to 7 of 7
Thread: Past winners
    Jan 2005
    Canton Ohio
    52
    Is there a list on the web that has all the past winners and what they drove?
    Nov 2005
    Woodstock, GA
    547
    We're working on improving the format, but you can find the results from 2000 until 2005 on the ARRC website, www.ARRC-Online.com. You'll have to go into each of the group listings to see what cars were running, but that should give you the info you're looking for.
    Butch Kummer
    Former SCCA Director of Club Racing (July 2012 - Sept 2014)
    2006, 2007, 2010 SARRC GTA Champion
    Jan 2005
    Canton Ohio
    52
    Butch, I appriciate the info. Been to that site already. I was specifically interested in the ITC races in the 90's.
    Nov 2005
    Woodstock, GA
    547
    CaptJon,
    Updating the event's history is one of the things we hope to get done this year. We've got results back to 1994 when the event started, but they're not in electronic format. My immediate goal is to update and confirm the track records since the track configuration was last changed in 1998 and create a set of "ARRC Records" sort of like the Olympic records - they can only be set during the ARRC sprint races. With everything else we've got going on time is the deterrent, but I can get you the '98 & '99 ITC winners with a minimum of effort this evening. '94 thru '97 will take a bit more effort but I'll see what I can do.
    Butch Kummer
    ARRC Committe Chairman
    Butch Kummer
    Nov 2005
    Woodstock, GA
    547
    Ends up we only had '99 readily available (the track configuration changed after the '98 season), but we'll eventually get results for all the ARRCs on the website. The ITC winner in '99 was Tracey Nine in an '85 Honda Civic with a best lap of 1:51.482.
    Butch Kummer
    May 2005
    Staying off the walls
    1,049
    Butch if you need help inputting the information give me a call. As long as needs to be in some MS Office file format.
    Tom Sprecher
    Oct 2005
    5
    Butch,
    If there is a way to separate the info, I would be able to spend some time helping out also.
    Bob,
    Atlanta Region
    National F & C
    [email protected]
