I believe that will meet the minimum requirements, although I don’t know the weight and did not look up the tubing size. I would if I were you consider a custom cage. There are some good builders in the area like Chris Howard. With a custom you get stronger, more stiffening and more interior room. With your car model so popular with the track day and rallycross crowd I think you could resell the bolt in cage pretty easy. It would be worth a couple of phone calls to check it out.
dick patullo
ner scca IT7 Rx7
