Soon our new line of high quality hardened wheels studs will be available.
Check out the prototype here:
http://forums.bildon.com/topic.asp?TOPIC_ID=19
Looks good bill. Don't forget to provide the suggested tools for installation since you dont have the hex or similar casting on the tip.
James Brostek
MARRS #28 ITB Golf
PMF Motorsports
Double nut to tighten and red locktite worked fine for me.Don't forget to provide the suggested tools for installation since you dont have the hex or similar casting on the tip.
~Jason
Jason Benagh
Steward - NER SCCA
ITB 1995 VW Golf
True, sucks to remove that way later on. But then if they are cheap enough I wont need to worry about that.
James Brostek
MARRS #28 ITB Golf
PMF Motorsports
Yes it is not as easy to remove. I have removed them when I borrowed parts at the track though. Those ones are now spares and will be used again if I borrow parts. New parts will get new studs.True, sucks to remove that way later on. But then if they are cheap enough I wont need to worry about that.
Jason Benagh
Steward - NER SCCA
ITB 1995 VW Golf
