Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: Wheel Bearings & Hubs...
    Apr 2001
    NH, US
    3,821
    I am changing the front wheel bearings in my 93 VW Cabrio (I know I know, save the comments, I do have a wonderful Girlfriend) as they are making noise. It is my first time attempting to change the bearings with my own press, In the Audi's we have always sent them out to be done. What a learning experience... lets just say they should have been done tonight, but they are not, errrrr. lol
    Anyway my question... sorta builds on previose discussions.
    Street Car:
    How often do you change the wheel bearings?
    When you change the wheel bearings do you also change the hubs as standard practice?
    What if the bearings were making that anoying groaning noise, do you change the hubs then?
    Race Car:
    I think the concensus is every 6 or so races/weekends or every 750 - 1,000 miles.
    I think the concensus is yes, you do change them everytime while it is apart.
    Raymond "More interested to know if I should be changing the hubs in my cabrio or if it is unnessesary" Blethen
    RST Performance Racing
    www.rstperformance.com
    Oct 2003
    Portland Oregon
    102
    Raymond
    We will not replace hubs on a street car unless they are damaged by the wheel bearing. Our general rule in my shop is if the inner race presses off with the hub, and you have to press the race off the hub then the hub is most likely ok, if there is no sign of heat damage. If the hub has scoring, from the bolt on Audi's or the nut on VW's, being loose or from the bearing going really bad for long enough then by all means replace it.
    With that said I will replace my hubs and bearings every season or 12 races and I will only use the German hubs and FAG bearings packed with Swepco, Redline or Mobil 1 grease. We can buy hubs made in China for $9 our cost, I just have a problem entering a turn on $9 hubs. I did send this set of front bearings and hubs to the cryo treater to see is we could get more life out of them and this set has lasted me 17 races so far. I will torque the nut to 200ft/lbs every time I hit the lugs with a toruqe wrench and I rotate tires with every heat cycle so the nut stays nice and tight. If we have a bearing fail in the front we will always replace both sides, hubs and all. We will only replace hubs and bearings on our clients race cars or track cars.
    Why are you sending them out, buy the wheel bearing tool from Snap On or AST and do it yourself. You can even do it on the car without removing the strut. I have had my press tool for 15 years now and besides my pen that tool has paid for it's self 1000 times over. If you do a lot of work on VW and Audi's, hell any European car that is, then this is the tool to have, even works on some of the other import cars and american iron too. BTW be carefull if you lend the tool out, mine has come back broken or bent a couple of times. Try to fing someone that has one and use it before you buy it, once you have used it you may question hou you lived with out one. I think the tool # is YA8450 but Snap On's web site sucks for info or pictures.
    Jon
    Ottawa, Ontario, Canada
    665
    Agree on the hub re-use -- that is, okay to reuse if it looks okay and race has to be pressed off. Definitely replace it if the hub just falls out of the race! Also agree on hub quality. The German ones seem to be forged, while some others are apparently cast. I ended up with a new cast one recently, and I'm afraid to even give it away. I have the special tool (and usually bring it to every race) if you want to try changing a front bearing with the upright in place.
    2006 NARRC ITC, 1ST
    2006 NERRC ITC, 1ST
    2000 NERRC ITB, 3RD
    BUGCITY -- RANCO Collision -- FlameTheHorse -- Shine Racing Service
    Jun 2005
    MD, US
    1,333
    From more then one source replace the hubs and bearings once a season. Mine so far look good, so I will do it over the winter and be ready for next season.
    On street cars, I only replace the hubs when they are damaged by a bad wheel bearing or cross threaded by someone. Otherwise that inner race comes off easilly with a press or with my super duper JamesB welded 5 dollar gear puller.
    James Brostek
    MARRS #28 ITB Golf
    PMF Motorsports
    We typicall replace the bearings and hubs together before each long enduro, and let the rest of the racing use up the left over wear.
    Somewhere in the swamps of Jersey
    399
    <SNIP>
    Why are you sending them out, buy the wheel bearing tool from Snap On or AST and do it yourself. You can even do it on the car without removing the strut. I have had my press tool for 15 years now and besides my pen that tool has paid for it&#39;s self 1000 times over. If you do a lot of work on VW and Audi&#39;s, hell any European car that is, then this is the tool to have, even works on some of the other import cars and american iron too. BTW be carefull if you lend the tool out, mine has come back broken or bent a couple of times. Try to fing someone that has one and use it before you buy it, once you have used it you may question hou you lived with out one. I think the tool # is YA8450 but Snap On&#39;s web site sucks for info or pictures.
    Jon
    Okay, so first I PM&#39;ed Jon for more information about this tool as I need to do a similar on the daily driver and figured any tool that would let me take the entire job in-house isn&#39;t a bad thing. That, and I&#39;m a sucker for new tools. Then I got bored while waiting to hear back from Jon, so I tried to find out more for myself. Such is the power of the &#39;net, a fast connection, and a slow day at work.
    There wasn&#39;t a Snap-On listing for the tool Jon described, but there was for a YA9240. Unfortunately, it is no longer available. Calling Snap-On produced a link to the original manufacturer of the tool, Schley. Schley no longer makes the tool either, because they couldn&#39;t compete with the "cheap Chinese importer who was cloning the thing." That led me to said importer, OTC, who still manufacturers / imports / supports slave labor /&#39; whater to have the thing - the OTC 6537 Hub Tamer Elite ( http://www.otctools.com/products/detail.php?id=1736 ) It truly looks like a neat tool to have.
    Sadly, it lists on the far side of $650, but can be found on Amazon and e-scam for between $200 - $300. A local distributor had it for $450. Ouch. That puts my usage and ROI out around the great-grandchild range. Dang. It looks like I&#39;m taking it to the local machinist after all.
    Hero To The Momentum Challenged
    Sep 2005
    Sacramento, CA
    13
    I bought my Schley Products (SP Tools) wheel hub/bearing setup from Toolsource.com about two years ago. Looking at Toolsource&#39;s current online catalog (click on link below) they still list the components under SP Tools...but the question is are the components still available. I believe that SP Tools shipped direct to my house after I placed the order though Toolsource. Below is a photo of my set up and a parts list from Toolsource:
    http://www.toolsource.com/ost/results.asp?...d_id=&sourceid=
    SP Tool # Part Description Price
    83500-1 7/8" 9 x 10" Special Bolt (1) $28.95
    83500-2 7/8" x 2.45 Special Nut (1) $10.95
    83500-3 12mm x 1.5 x 80 mm hub removal bolts (2 needed) $11.75 (each)
    83500-7 Pusher Washer 2.438 x 0.700 (1) $18.95
    83500-5 3" diameter x 1.8" Sleeve (1) $16.95
    86300-3 3 3/8" diameter Cup (1) $29.95
    total $129.25
    This might be a dead end...which is a bummer. The quality of the SP Tool components are very high since they are made for professional mechanics who use these tools much more frequently than the occasional use frequency of a racer/mechanic. Here&#39;s a link to a tech tip I put together awhile back on how to use this tool...hope it helps... http://www.norcalgticup.com/frontwheelbearingr&r.html
    Rapid Parts use to rent out the tool...you might check with them to see if they still have one to rent. I think I paid ~$35 to rent it (and had to put a ~$250 safety deposit on it).
    http://www.rapidparts.com/
    Good luck,
    Scott Neville
    #44 NorCal GTI-Cup
    Scott Neville
    #44 Nor Cal GTI-Cup
    2004 GTI-Cup Champion
    Jul 2002
    Souderton PA
    43
    Try this http://www.harborfreight.com/cpi/ctaf/disp...temnumber=45210
    It&#39;s even on sale ~$60. While it&#39;s not the quality of the Schley set it works great. I&#39;ve done over 20 wheel bearings with mine (wait and see how popular you get) and there&#39;s no signs of wear. The hard part is still removing the hub, same as with the Schley if I recall. You&#39;ll need a couple of really long bolts with the same thread as the lugs. If you don&#39;t use lug bolts it can get real interesting.
    -Bob
    665
    I&#39;ve got the Schley tool. Bought it over 6 years ago and don&#39;t remember the price (maybe $300?). Three of us went in on it originally, and then I bought them out over the years. Comparing to the picture above, I believe that mine also came with several different adapter plates to fit different cars (VW, Audi, Porsche, etc.).
    2006 NARRC ITC, 1ST
    2006 NERRC ITC, 1ST
    2000 NERRC ITB, 3RD
    399
    Scott - thanks for the excellent write up. I&#39;ve just gotten off-line from the Timken site, checking to see how the dimensions of Toyota wheel bearings stack up against the parts you listed for your A1 VW application. (The car in question is a 2000 Corolla, no ABS.) The only problem I see is in the removal of the hub assembly. Unlike VW&#39;s, Toyotas have conventional wheel studs that are swaged into the hub, which eliminates the possibility of using the hub removal nuts you listed to press the hub off of the carrier/bearing as you described.
    Bob - thanks for the link to the HF tool. It may well answer my questions. However, I still have to address the issue of getting the damned hub out of the way.
    All - I&#39;m thinking of using a three jaw puller to remove the hub from the carrier. In order to do this, however, I need something for the puller to work against. This would appear to be the axle. Can I use the three jaw puller against the axle (in other words, with the axle still in place) to remove the hub? Step 7 of Scott&#39;s write up indicates that is the way it was done, am I correct in this assumption?
    Rob
    Jun 2005
    MD, US
    1,333
    HF no longer sells my bearing kit. But mine had a slide hammer to remove the hub. only once did it take me more then a 3-4 good hits to remove the hub. From there everything is spin out spin in including the hub. I use a small modified 2 jaw gear puller with a custom clasp to hold it in place to pull the outer race off the hub.
    But then I been doing wheel bearings on my cars and as side work for about 4 years and nearly perfected my version.
    James Brostek
    MARRS #28 ITB Golf
    PMF Motorsports
    Sep 2005
    Sacramento, CA
    13
    It appears that SP Tools (Schley Tools http://www.sptool.com/ ) still makes the wheel bearing tool for Audi and Volkswagens.
    I was able to order today (9-19-06) a new pusher washer/disc for a larger wheel bearing (for the 68mm bearing--2.625 inch disc) today from Toolsource.com. http://www.toolsource.com
    Go the their tool search feature and type in "Schley" and use the parts list I supplied in my earlier post.
    I really am impressed with Toolsource&#39;s customer service. I e-mailed them asking about the larger pusher washer/disc and within a few hours they had e-mailed me back with a brand new web link to the part. I doesn&#39;t get any better than that in my book.
    Keeping my fingers crossed that SP Tools still makes the tools....I&#39;ll update this post when I find out.
    Scott Neville
    #44 Nor Cal GTI-Cup
    Apr 2001
    Belmont, CA USA
    1,098
    Forget all of the tools and home remedies. Just take the hub/bearing to a VW shop and tell them to install new GERMAN bearings, not the Brazilian units, and forget about it.
    Sorry, but it&#39;s "food chain" to me. Yes, I enjoy rebuilding motors, dis-assembly, re-assembly, but some things just need to be done by "pros".
    Just like rebuilding trannies. WAY too many moving parts for me, but I&#39;m more than comfortable rebuilding a head, AFTER the new valve guides and seats have been installed, and I can lap the valves, and re-assemble and port the head.
    Tim Linerud
    San Francisco Region SCCA
    #95 GTL Wabbit
    Convert from GP to GTL
    racer_tim @ yahoo dot com
    Sep 2005
    Sacramento, CA
    13
    Hey Tim,
    I totally agree using the best quality bearings/hubs as that&#39;s not a place to cheap out. And I won&#39;t tackle the insides of a tranny either. But the front wheel bearings aren&#39;t rocket science. Owning the tool that the pros use (Schley) has paid for itself a bunch of times for me and my fellow Rabbit racers (who have borrowed the tool) and it has proven invaluable as on numerous occasions we have replaced bearings and hubs at the track thus saving the weekend for a racer.
    Cheers,
    Scott
    Scott Neville
    #44 Nor Cal GTI-Cup
    Jun 2005
    MD, US
    1,333
    Always use grade A parts thats a given. But as said before, that tool pays for itself in one use. In the amount of time it would take me to remove the two spindles just to go down and pay 1-2hours time for a person to press it I could have paid for the top parts and finished the work.
    Its not rocket science, thats why I dont build my own motors though I am learning the tricks to that so I can reduce my costs.
    James Brostek
    MARRS #28 ITB Golf
    PMF Motorsports
    Apr 2001
    Belmont, CA USA
    1,098
    Scott I believe in another process. Bring enough spares to rebuild each front corner to the track. If I don&#39;t use them, and continue to bring them to the track all year, oh well. I bring a spare strut, hub, control arm, brake caliper, rotor, brake pads, and 1/2 shaft for each side to EACH race weekend.
    But I do know, that the hub and 1/2 shafts will be next years parts on the car, and the old ones with go to the pro&#39;s to have the bearings replaced.
    Every year I also replace the entire 1/2 shaft assemblies. They get removed, replaced, and the spares that I carried all year long, go on the car, the the old ones are turned as cores and replaced as an entire assembly.
    We all know that the front end of the VW is the weakest link, and since I run a locked diff, the stress is even greater.
    I lost a hub when I went up on 2 wheels @ Sears during the re-construction in 2001, and I&#39;ve lost a CV joint in 2003 @ Thunderhill. Luckly, I lost the hub on the last lap and actually finished, and I lost the CV in practice or qualifying, so I was able to replace it, and still finish the weekend.
    Tim Linerud
    #95 GTL Wabbit
    Flagtown, NJ USA
    6,335
    Tim,
    I used to do the same thing, take complete spare corners w/ me. I even had a spare rear beam in the trailer. Mostly I ended up lending the stuff to friends that needed them.
  18. #18
    Jul 2006
    Sandwich, IL
    15
    I have been running the same front bearings and hub assembly for about 5 years now. I think I have streched my luck far enough. I called my local parts store and the brearings they carry are Fedral Mogul. The price is $63 per bearing. is this a good brand? also, arent these sealed breaings? The reason I ask is that someone mentioned about using synthetic grease to pack the bearings. Mabye it was the rears they were refering to.
    Thanks for your help.
    #98 Silver Golf. RIP
    I loved that car.
    Michael
  19. #19
    Sep 2005
    Sacramento, CA
    13
    Got my pusher washer yesterday....still Made in USA too!
    Mike98
    SKF front wheel bearings for a Rabbit (64mm) are $18.85 each at http://www.audicarparts.com
    Scott Neville
    #44 Nor Cal GTI-Cup
  20. #20
    Mar 2003
    138
    I had the grease escape from my left front last weekend during the Sat. race at IRP. Pulled the spindle and ran home (20 minutes) to replace the hub/bearing. Returned and put it back together, torqued the axle nut and the bearing locked. Removed the assembly, inspected and reassembled and voila! - same result. Back to the shop with spindle, removed bearing/hub and put new together. Back out in the morning, put the spindle back on the axle shaft and snugged the nut down. Same thing, locked the bearing. Lightly tapping with a small ball peen on both bearing/hub assy&#39;s freed up the bearing until they were again tightened. When I pressed the bearings into the spindle, I pressed on the outer race, and pressed the hub into the bearing using the inner race. The bearings are FAG&#39;s and the hubs are Brax. I have done this procedure a few times and this was the first time I have had this problem. Perplexing, to say the least. Anyone else seen this aggravation?
    Jim Sexton
    …I feel ill at how far we have drifted from engineering and automotive integrity. It's not just nostalgia. It's more like sorrow. For a shining moment in human history all our science and engineering blossomed to create the great inventions and designs. Now we engage in techno-masturbation like Twitter and TPMS…
    Riley Tharp
