OK, I was trying to remedy an apparent oil leak on the top end of the motor (oil residue on the intake manifold next to the motor, but none on the exhaust manifold - burns off?)
As I installed the cover, I discovered that one bolt on the right rear of the head is stripped to the point where it will not tighten.
Possible options are: 1) reinstall the bolt with blue loctite or 2) fill the hole with some liquid metal, drill and tap the new hole (assuming that I have the correct tap).
Opinions?
Thanks.
