Every thing said above is correct, but it could also be the cam seal, or the valve cover gasket. If the valve cover gasket was not sealed when it was installed (honda bond in the corners at the cam towers) it will leak down inside the timing belt covers. So when you get it all apart look very carefully for the source of the leak, if you can't be sure replace all 3.
