Results 1 to 5 of 5
Thread: part cleaning
    Jul 2001
    Chicago, IL
    253
    I am tearing down a donor motor that has been sitting for a couple years in the corner of the garage - I am going to have the block bored out and re-do the head. Is there a way to clean up the gunky and dark brown stained parts besides sandblasting? any special tricks to getting things cleaned and degreased? thanks
    Trussville, Alabama, USA
    1,087
    Go to your local transmission shop with your aluminum parts and beg them to put them through their degreaser...works great! Chuck
    Chuck Baader
    White EP BMW M-Techniq
    I may grow older, but I refuse to grow up!
    Oct 2004
    Asheville, NC US
    1,626
    Go to your local dollar store and buy some oven cleaner. Works great to remove the caked on grease and will even lift the tar and goo off rubber parts without damage. Best no scrub cleaneer you will ever use. Follow with a good purple or similar cleaner to remove the residue. Cashier looks at me like I'm crazy when I buy it by the case.
    Steve Eckerich
    ITS 18 Speedsource RX7
    ITR RX8 (under construction)
    Apr 2002
    Pottstown, PA, USA
    95
    Castrol SuperClean.
    Banned.
    Buffalo, New York
    2,942
    Don't ever sand blast.
    You can use the various cleaners described above, but if it is that "gunky," pay to have the block cleaned by the shop that will be doing the heavy work (boring. honing). They will either have a hot tank (not likely any more), an oven or high pressure system, but any of the methods get the block clean.
    Cheers.
