***What would, in general, be the kinds of things to start modifying in order to move up to IT7 ( with hopefully then to G-Prod. )***
Greg, is it safe to presume that you sent a letter/e-mail to support the classing of the 1st gen to G Production per Scott's classing request.
My conversion from SRX7 to ITA/IT7:
2004
4:88 gear ( at S.P. you might want a 5:12)
Complete exhaust syetem including header
Header heat shield (heat from header away from carb)
Blueprinted carb, Holly red pump/ Holly regulator/cool air intake
Two row cross flow water radiator
Oil temp/oil press/water temp gauges
Dual EGT gauges
2005
Complete suspension
Tube front sway bar/ alum arms/ dbl rod end links
Springs/adjustable spring perchs
Modified struts/inserts/shocks
Center link
lower links with rod ends
Panhard bar mounted to chassis on drivers side (installed brackets so the rear sway bar could be used both ways)
EDIT:
Get rid of all that stuff & get that car down to 2280 with driver for ITA/7
Add welded S.B. (Scott bearings :P ) at all locations
Early 1st gen oil cooling radiator modified for oil cooling.
I went through the weights of a 12 gal alum fuel cell vrs the OEM fuel tank & weight wise it makes zero sense to do a fuel cell.
Have Fun ; )
David Dewhurst
CenDiv Milwaukee Region
Spec Miata #14
