Results 1 to 7 of 7
Thread: power steering
    is it legal to remove ps and just loopback the rack on itself if the car had manual steering option? the power steering rack has a different ratio then manual. or do i have to buy a manual rack?
    Jun 2001
    Milwaukee, WI
    1,193
    You'd have to install the manual rack. Cars can only be updated/backdated using whole assemblies.
    "Most people have the will to win, few have the will to prepare to win.” - Bobby Knight
    Bill
    Planet 6 Racing
    thanks bill - figured thats what id have to do..car is months from racing so for now will just loopback but keep eye out for used manual rack.
    last ? for at least a month - how about opening the strut chassis thru hole at the top to increase camber/caster range?
    shawn
    Oct 2002
    Wandering the USA
    1,341
    d. Suspension Mounting Points
    1. Cars equipped with MacPherson strut suspension may
    decamber wheels by the use of eccentric bushings at
    control arm pivot points, by the use of eccentric bushings
    at the strut-to-bearing-carrier joint, and/or by use of
    slotted adjusting plates at the top mounting point. If
    slotted plates are used, they shall be located on existing
    chassis structure and may not serve as a reinforcement
    for that structure. Material may be added or removed
    from the top of the strut tower to facilitate installation
    of adjuster plate
    Marty Doane
    ITS RX-7 #13 (sold)
    2016 Winnebago Journey (home)
    of adjuster plate
    yeah i wasnt sure if i could use that as basis to open the hole up for greater range or just the installation.
    Mar 2001
    Connecticut
    7,381
    And only if the rack was optional equipment. The Nissan NX2000, for example, came with the power steering rack as standard equipment, and it is illegal to install the NX1600 manual rack. - GA
    May 2003
    Colchester, CT, USA
    2,120
    He's baaaaaack!!!!
    Jeff L
    ITA Miata
    2010 NARRC Champion
    2007 NERRC Championship, 2nd place
    2008 NARRC Championship, 2nd place
    2009 NARRC Championship, 2nd place
