I'm thinking custom bladder using stock steel tank as the metal enclosure. I guess the filler could be either at the stock point or where the level-sensor mounts. I'd probably use a low-pressure transfer pump inside the cell. Has anyone done it this way? Do any of the fuel cell manufacturers already have this mold?
Eric,
Stu at BSI had a really trick cell made by ATL that bolted into the stock location, had internal baffles/surge tank system with an internal pump. He had this made for the GP Scirocco he built for Jim Anderson. Cost him about $1200 IIRC.
Call Stu, I'm sure he can help you.
MC
Mark Coffin
#14 FP VW Scirocco
Former ITC roustabout...
