Thanks but still baffled about helmet check. You get it checked with your car every year. Couldnt a stamp on your member card verify you're set for 06. Then when you check in to reg. the scca helper sees this and gives you the roll bar sticker?
A sticker on your license would work as well as a sticker on your helmet, but Tech would still need to see your logbook before issuing the event sticker. The reason for this is that we are checking to see that your car had its annual inspection this year and that it hasn't had any write-ups (crash damage or compliance) since the annual that need to be checked before you go out again.
Ty Till
#16 ITS
Rocky Mountain Division
2007 RMDiv ITS champion
