Results 1 to 6 of 6
Thread: I need some more fuel.
    Dec 2004
    122
    If a guy was too cheap to invest in a MOTEC, and wanted to stay legal for ITS, what can be done to get more fuel into the motor using the stock ECU? I've got an '87 13B S4 motor with S5 throttle body.
    I know MOTEC allows you to change duration, but it's a little expensive. What about some gizmo to trick the stock ECU into thinking the air is super cold? Any other way???
    Steve Smyczek
    Jun 2003
    boston, ma
    211
    Steve Smyczek
    Adjustable fuel pressure regulator. That's the easiest and cheapest way I can think of. Just turn the fuel pressure up.
    s
    May 2005
    ft mill s.c. lancaster
    12
    you can also use turbo injectors in the secondaries with 42 psi worked on our car before we got the motec. ralph car chief ITS #86
    Mar 2003
    Somewhere in NC
    969
    Evan Darling
    ITR BMW 325is build started...
    SM (underfunded development program)
    SEDIV ITA Champion 2005
    sometimes racing or crewing Koni Sports Car Challenge
    Floyds Knobs, IN
    1,093
    Uh, not legal...
    You need more fuel with the S5 electronics? Are you sure? EVERYONE says the S5 is too fat.
    Chris Ludwig
    GL Lakes Div
    www.ludwigmotorsports.com
    Oct 2004
    Manchester, MA
    68
    If everything is working correctly, I agree with Chris you will be quite rich. I'd first have the injectors cleaned and tested at some place like Marren in CT.
    I fought a lean problem last year until I was ready to give up. The issue was repeatedly clogged injectors. I drained the tank and replaced the screen and filter but didn't find any obvious contamination.
    The ACV block off plates rtv had deteriorated and I believe it was allowing exhaust and intake air to comingle in the lower intake manifold. There was a lot of fine black carbon looking residue in the intake. When I returned the newly serviced injectors to Marren they were clogged again after only 3 dyno runs. That's when I drained the tank and resealed the ACV blockoff and haven't had a problem.
    One way or another I would suspect the injectors. They do fail or get weak fairly regularly due to the vibration and heat they experience especially the primaries.
    Jamie Kekeisen
    86 ITS RX-7 NER
    92 325IS oops, blown up
