I have a CRXsi 89
I need a nice nose to easy on and off. Does anyone have an Idea. I used Blanney`s but It was big and draged. How about a smaler one that is removalble.
Thanks Scott
I have a CRXsi 89
Thanks Scott
<span style="font-family:Impact">Scott CRX NER ITA #0</span>
Scott!!!
It dragged because either you mounted it wrong, or you did a little too much agricultural racing...
The unit is held on with 4 Zeus fasteners, how simple can that be...
The only time I lost one is skipping through a gravel or dirt trap. Keep it on the track, remount it correctly or replace the belly pan if you bent it up. The pan can be replaced with a drill and some pop rivits.
The unit is suppose to follow the plane of the lower valance and extend back to smooth the air below the car, while the splitter lip creates downforce.
Relax Tom
It dragged on the 2nd reason. It is a fine nose I was not putting down your nose. So don`t get your nose all bent. I thought you were out of Bus. So I am looking for a new nose.
So if you have any news on a nose let me know`s. I was hoping to find a slimmer one thought I have seen them on Integras. I want the slimer Hollywood tip with a curl on the end.
Scott
Happy snose.
