Results 1 to 12 of 12
Thread: Brake Pad Material
    Oct 2001
    Torrance, CA
    305
    Hey gang. Ok, yet another question. So, Im looking at brake pads and shoes and am wondering how much pad is enough? For instance, do I need the latest and greatest pad with the super-high temp rating to race, or will an "autocross" pad be enough for my 2300lb ITB car? Im basically looking for the pad that will give me enough braking power and durability without going overboard. The fact that I can get autocross level pads for my car vs. needing to have full race compound pads made plays into this as well. Thoughts?
    Ryan Walsh
    Cal Club
    Formerly building ITB Corolla
    Now building ???
    "I remember the immortal words of Socrates when he said, 'I drank what?'"
    Dec 2001
    raleigh, nc, usa
    5,252
    I wouldn't skimp on the brake pads for the fronts. They will do most of the work. For the rear shoes, stock is probably fine at first.
    NC Region
    1980 ITS Triumph TR8
    May 2003
    Colchester, CT, USA
    2,120
    Agreed, go with the best road race pad you can find in the front. Granted, the car is only 2300 lbs, but most of the ITB cars have little dinky pads/rotors and you will be amazed at how easy it is to over heat with the wrong pad.......
    Jeff L
    ITA Miata
    2010 NARRC Champion
    2007 NERRC Championship, 2nd place
    2008 NARRC Championship, 2nd place
    2009 NARRC Championship, 2nd place
    Buffalo, New York
    2,942
    Never skimp on front brakes!
    Proper race pads are necessary; Hawk blues are real good.
    If you are running an FWD car, stock rear drum shoes are more than adequate. Your front brakes will be doing 80% of the braking.
    Warren, Ohio USA
    110
    Good brakes for the front is certainly a serious consideration. To balance this against cost is also a consideration. For the past 15 years I have used the NAPA Raelok Premium product (now just their Premium brake pad) and have had no problems. I used them on my IT-B Pinto for 6 years and on my Renaults at both Nelsons and Mid-Ohio, two very different tracks, brake use wise. No one is outbraking me and they don't fade for me, so they suit me just fine and save me about $125 or more ($45 compared to about $170) a set over the Premium Carbon Metalic Racing pads. They last me about 6-8 race weekends. If your driving style has you on the brakes more than I am, you might find a point at which they fade, so no guarentees. I am able to run up front in the race group my car is in, so they work for me.
    Carl
    Flagtown, NJ USA
    6,335
    Two words, Hawk Blue.
    May 2005
    Staying off the walls
    1,049
    I run Hawk Blues on all 4 corners of the RX-7. How far can you run the pads down before it's time to change them?
    Tom Sprecher
    Oct 2002
    Wandering the USA
    1,341
    When I ran Blues they ate rotors faster than pads.
    Marty Doane
    ITS RX-7 #13 (sold)
    2016 Winnebago Journey (home)
    May 2005
    1,049
    So whadja do instead?
    Tom Sprecher
    Sep 2001
    hampden,ma.usa
    3,083
    I have found it to be a mistake to run them past half thickness.
    dick patullo
    ner scca IT7 Rx7
    Oct 2002
    Wandering the USA
    1,341
    Switched to Carbotech. I think the dusting might be worse with fresh pads (which is a real pain with my white wheels), but they're much easier on rotors, last longer, and have great modulation. They need to be warmed up, though. My parking brake hardly works when they're cold.
    Marty Doane
    ITS RX-7 #13 (sold)
    Feb 2003
    1,106
    Switched to Carbotech...snip..[/b]
    i am a big fan of Carbotech. call Larry at their toll free number. you can find them at:
    http://www.carbotecheng.com/main.htm
    Larry will likely only make recommendations after he knows what car you have, what class you race, what brake fluid you use, what tires you use, how good is your cooling, etc., etc.,
    they are very easy to talk to and see their brake pads as part of the overall braking system (my words, not necessarily theirs). without knowing what the other limitations of the system, they cannot know what will work best for your application.
    i have used several types in the past (including some from NAPA) and nothing has compared to the Carbotech for the front of my 2150# (with me and ballast) CRX. but then, i also use stock shoes in the back.
    tom
