Page 1 of 2 12 LastLast
Results 1 to 20 of 35
Thread: Almost ready
    Nov 2003
    Buffalo, NY
    127
    Installed the seat, new net (thanks Joeg!), redid the gauges, made many improvements to the wiring, sort of fixed the exhaust (still might get a new one fabbed), almost ready to go but I still have a lot of things to fix but they are mostly small things to improve reliability. More wiring work, new vacuum lines, fix the brake lines that are zip-tied to the cage, stuff like that. Anyone see anything in the pics that I missed?
    Seat installed and gauges before making new dash panels
    I put the oil temp and pressure where I can see them through the wheel, and the water and volt up where they were before, but now they are not facing away. I would like to rotate all the gauges so ideal is straight up, but I don't know where they are supposed to be with this car yet, what should they be? I have an oil cooler and oversized filter if that helps. where should the pressure be? And water temp? Voltage is 14 or so, it looks like I can just turn that one now.
    Ready for enduros
    Driver School: Complete (April 2007)
    Regional License requirements: Complete (June 2007)
    Race Car: Renting, started building my own
    First Win: TBD (3rd in Pumpkin enduro! ITA)
    Apr 2001
    Belmont, CA USA
    1,098
    Window net and belts would be good.
    As far as water temp. between 190 and 220 is normal
    Just make sure that both oil and water temp are at the same ends. I mean, if you have your oil way too cool, you don't want the water to be way hot, and visa versa.
    You might also want to get some tow hooks or eyes too.
    Tim Linerud
    San Francisco Region SCCA
    #95 GTL Wabbit
    Convert from GP to GTL
    http://www.timlinerud.com/racing/index.html
    racer_tim @ yahoo dot com
    Nov 2003
    Buffalo, NY
    127
    Thanks for the info.
    Window net is installed, belts will be ordered soon, car has 4 tow eyes, one at each corner, I painted the rear red, will do the front soon and add arrows on the bumpers.
    Flagtown, NJ USA
    6,335
    Car looks good! The color reminds me a lot of my old car.
    May 2003
    Colchester, CT, USA
    2,120
    Reliability and safety, everything else is a distant second!! Looks good though!
    Make sure your tow hooks are legel according to the GCR, not just the factory hooks.
    Oh, having fun is second behind reliability and safety!! Have at it!!
    I assume you'll be at LRP and NHIS for racing? (I just got rid of my ITB GTi this weekend, sad to see it go!!) It's a good group of ITBers in the Northeast. If you need help with ANYTHING, let me know.
    Are you going to the NHIS school?
    Jeff L
    ITA Miata
    2010 NARRC Champion
    2007 NERRC Championship, 2nd place
    2008 NARRC Championship, 2nd place
    2009 NARRC Championship, 2nd place
    Mar 2003
    Somewhere in NC
    969
    I would probably swap the oil temp and water temp locations as the water temp responds faster to a problem and should be part of your guage scan. On shorter tracks you dont have much time to look at them and it is easier to see water temp rise fast...if it does you can scan the other guages. If the oil temp is real high and you look to the water guage it will probably be of teh chart :119: just my .02
    Evan Darling
    ITR BMW 325is build started...
    SM (underfunded development program)
    SEDIV ITA Champion 2005
    sometimes racing or crewing Koni Sports Car Challenge
    Apr 2001
    NH, US
    3,821
    Looks like you need a Farfromaudi sticker!!!
    Also check the tow hooks, the factory ones are not legal (errrr) so you will need to make something up. On the Audi I took some cable and wraped it around the bumper posts... connected the ends of the cable with cable ties, and then tucked the cable under the bumper and duct taped it up so it isn't visible unless you need it (hopefully you never will). I would still use your factory hooks for tiedowns on a trailer.
    Anyway excited to run with you this year, come hang out and let us know if you need any help. We have a great group of people who help us and we don't mind sharing!!!
    Raymond
    RST Performance Racing
    www.rstperformance.com
    Buffalo, New York
    2,942
    Mike--PM me about exhaust--if you want to fab a new one.
    Flagtown, NJ USA
    6,335
    Why aren't the factory VW tow hooks legal? Was there some official ruling on this somewhere?
    Jul 2002
    Billerica, MA
    272
    Factory tow hooks on the VWs are not big enough, so they do not comply with the rules. I used cable last year, but they pulled right out. I switched to the locking rings from the hardware store. I tape them up to the bumper so they don't clatter around underneath.
    Jason Benagh
    Steward - NER SCCA
    ITB 1995 VW Golf
    Jun 2005
    MD, US
    1,333
    I need to do the same. But I was considering welding a 2" ID ring to the stock front and rear locations in a way they wont prodtrude from the bumper. Its on the to-do list for February.
    James Brostek
    MARRS #28 ITB Golf
    PMF Motorsports
    Jul 2002
    Souderton PA
    43
    For the cheap and easy route you can always use a spectra climbing runner looped through the factory tow point.
    -Bob
    http://www.rei.com/online/store/ProductDis...vcat=REI_SEARCH
    Jan 2006
    24
    Yo Bob Paul here just wanted to shout at ya. See you at pagoda hill . Paul
    Jul 2002
    Souderton PA
    43
    Hey Paul,
    It's so nice to see you still have the Golf. I hope to be out before Pagoda this year but we'll see.
    -Bob
  15. #15
    Nov 2003
    Buffalo, NY
    127
    Thanks for all the input everyone.
    So the factory tow hooks are not legal, but a $10 climbing runner attached to them is?
    Why? Are the factory ones too small? Because they sure are strong enough.
  16. #16
    Oct 2002
    newington, ct
    4,182
    Too small; not easily accessable when in a sand trap...
    Dave Gran
  17. #17
    Jun 2005
    MD, US
    1,333
    I would be surprised if they where larger then 1"ID. and I think I found something that will work well, be easy to access in a sand trap and make tech as well as EV happy.
    James Brostek
    MARRS #28 ITB Golf
    PMF Motorsports
  18. #18
    Nov 2001
    Wheaton, IL
    1,893
    And that is.....
    Chris Schaafsma
    Golf 2 HProd
  19. #19
    Jun 2005
    MD, US
    1,333
    I found some stuff at the hardware store while picking up some stuff for mounting my balast. I will post the picture this weekend since its ont he Saturday fabrication list. But its 2" solid rings I got for a buck a piece that I am going to weld up with some steel scrap I have here and use the same bolt locations that secure the front rebar with intigrated toe hooks for the front. The rear I am going to fab into using the rear bumper or weld it to the driver rear toe hook.
    I will gladly post all the pictures of the progress and final product for everyone.
    James Brostek
    MARRS #28 ITB Golf
    PMF Motorsports
  20. #20
    Aug 2003
    368
    Angry
    The spec is for a 2" ID aperture - that way EV can quickly hook on to your vehicle with their tow vehicle without having to resort to various J-hooks that fit the factory opening (or in some cases, openings in the undercarriage). Its all about speed in collecting your car in an emergency. Every tow truck worth its salt has "the right stuff" on board but with a herd of nut jobs whizzing by your disabled car on a racetrack, that EV worker is more concerned about moving you NOW rather than searching for the proper hook.
    In other words a 2" ID aperture is sufficient for most any tow vehicle hook from a tug-em strap to a winch hook to collect your car ASAP.
    Not trying to piss in your Wheaties but having friends who run a towing service AND EV, I hear this drivel constantly - it must have sunk into the dark recesses of the cavity that I call a brain.
    Haz-Matt Racing
