Results 1 to 6 of 6
Thread: Radio Question
    Jan 2005
    St.Louis, MO USA
    150
    Hey MiDiv guys (and gals)...
    How did (do) you determine which radio channels (frequencies) to use at the track?
    How many channels did you have programmed?
    Randomly chosen...or...???
    TIA
    Mark Andrews
    ITS '92 BMW 325is
    St. Louis
    Feb 2002
    Little Rock, AR
    554
    Well - if you'll read the supps, each track has its "forbidden" frequencies (at least in MiDiv). Pick anything else that works for you. Most of them are different - and most are in the high 151Mhz or 455Mhz range.
    Just looked - the forbidden frequencies at Gateway are 151.655 and 154.700.
    Jan 2005
    St.Louis, MO USA
    150
    Thanx Norm...
    I bought UHF P1225's in the 440-470 range I believe.
    I'll check all the MiDiv tracks and go from there.
    I was also trying to understand all the different competitors using radios...ie crosstalk problems.
    [snapback]72032[/snapback]
    Mark Andrews
    ITS '92 BMW 325is
    St. Louis
    Nov 2001
    Columbus, OH
    1,522
    It happens, occasionally you'll get some interference from other competitors radios. But when it does, just flip to another channel. There's not really any way to avoid it but just make sure the radio is mounted somewhere in the car that the driver can reach it if need be.
    On a side not, are you the same "buldogge" I've seen on other sites who occasionally makes alternate diameter crank pulleys for more psi on supercharged E36's?
    Kevin
    2010 FP Runoffs & Super Sweep Champion
    2010 ITB ARRC Champion
    2008 & 2009 ITA ARRC Champion
    '90 FP Acura Integra RS
    '92 ITA Acura Integra RS
    '92 ITB Honda Civic DX
    Jan 2005
    St.Louis, MO USA
    150
    Yep... That's me...
    We can also make underdrive pulleys...oversized alternator...etc.
    Really any machining/fabricating/welding you (or anyone) needs done!
    Thanx
    [snapback]72093[/snapback]
    Mark Andrews
    ITS '92 BMW 325is
    St. Louis
    Nov 2001
    Columbus, OH
    1,522
    Originally posted by buldogge@Jan 25 2006, 07:29 PM
    Yep... That's me...
    Thanx
    Good deal. I only noticed because my street car is a Dinan supercharged '95 M3 so I've looked at your pulleys before on the bimmer sites. If I ever get the funds for a cooler, I'll be looking to up the boost to around 10psi. 350+rwhp just sounds fun as hell!
    Kevin
