Not sure if you need 4deg of camber. I run about 3.25 deg of camber on my Jetta with Toyo RA-1s, 205/50/15s. What makes you think you need 4? Start at three, and then use a pyrometer to check your temps, pressures, etc. Then go higher, watch the inside tire. With too much camber, and wheelspin on tight corners they really get hot on the inside - and with that much camber on the straights too - it will be noticable.
Rob Microys
1986 VW Jetta Coupe, CASC-OR GT-C
2005 Ontario Challenge Cup class GT-C Champion
3rd place overall points in Ontario, 2005
