Ok, don't throw anything at me but what keeps my Isaac from meeting SFI 38.1?? I'm assuming the concern is the "implied" single point of release in Section 2.5. If that's it, then my Isaac passes. That section indicates that "... no additional motion is required, other than the release of the seat belts, to disengage the Head and Neck Restraint System...." The only thing that is needed to disengage my Isaac is the release of the seat belts "from the Isaac". Section 2.5 doesn't define the method needed to "release the seat belts". In my case I have to remove a ring and a shaft from each shock to remove the shock from the shoulder belt. Nor does Secton 2.5 define what we are "releasing the belts from". I think we've all been assuming that it means releasing the belts from the driver but it doesn't state that. Therefore I feel free to assume that it means releasing the belts from the Head and Neck Restraint System. I think we've been reading too much into SFI 38.1. Any thoughts??
Scott Gallimore
worker, nat comp license, IT-7 driver,
North Carolina Region Board of Directors, Member at Large
