Results 1 to 8 of 8
Thread: Merkur Parts
    Nov 2001
    Bunker Hill,WV.
    614
    One of my friends, against my advice, bought a Merkur XR4Ti. He needs motor mounts for it. Any suggestions on where to get these?
    It is a street car. But I figured the ford racers might know this one.
    "dangerous" dave parker
    wdcr ITC-> HP #97
    "Ignore All Confrontations With Common Sense."
    Jul 2004
    Raleigh NC
    3,682
    wdcr ITC-> HP #97
    [snapback]66496[/snapback]
    They should be the same as the Mustang SVO 84-86 mount. I say should, because I know the fox chassis is slightly different from that chassis, but the transmission and engines are the same. If that does not work I would bet that the mounts from a Cosworth Sierra , sold in England, will be the same and those are readily available overseas. In fact, any 2.3L Mustang mounts might work because I don't know for certain that 2.3L NA have different mounts than the 2.3L Turbo engines.
    You could also try the Thunderbird TurboCoupe mounts from 84-88 since the same engine and driveline are present there too.
    Excellent little cars and can be made very fast. I used to have an 86 SVO and with about 22-25lbs of boost the little fellow could put down 310-320 at the wheel. More was easily obtainable with a cam swap, cheap and easy, and turbo upgrade to a T04E/50 compressor trim with T3 turbine. Hybrid setup. Go to a large Volvp front mount intercooler for cheap power and durability, plus, you can go to a large valve head too if you are inclined. www.corral.net is a good source, and I have seen some of the SVO mills making 420+ rwhp with $2.5k of investment. Bottom end are stout pieces, leave them along until they pop.
    Jul 2002
    Arlington, VA USA
    515
    Dave-
    I couldn't belive my eyes but there were four or five XR4Ti's sitting outside one of the Gasoline Alley garages at Summit during drivers school. Maybe a midnight recon mission?
    Kidding....
    Gregg Ginsberg
    '96 Civic EX -- MARRS ITA #72
    WDCR-SCCA Rookie of the Year 2003
    MARRS ITA/T3 Drivers rep
    Hartwood Auto, I think it's in Fredricksburg, VA.
    What time is that raid? I need a transmission.
    Nov 2001
    Bunker Hill,WV.
    614
    Thanks to all for the info.
    As the son of a U.S. Navy officer and a person actively involved in the retail market I am sure that you all know exactly how I feel about thievery and stealing. So we won't go there.....
    But I will pass this information on to the owner of the Merkur.
    Thanks again.
    cheers
    wdcr ITC->HP #97
    buffalo,n.y. u.s.a.
    357
    There are many resources for the Merkur. One site I've used is:
    http://www.merkurdesktop.com/desktop.php
    Many of the clubs listed on the site have FAQ, and parts sources. Hope this helps.
    Good racing.
    Bill
    Jul 2002
    Arlington, VA USA
    515
    Gregg Ginsberg
    Dec 2002
    Pittsfield, NH,USA
    92
    Re motor mounts for Merkur.
    Contact Dan Malek at '[email protected]'.
    He has a Merkur and a mid 80's 4 cyl Mustang. Plus he knows a ton about thexe cars. He is in NH.
    Best Regards - Bill Miskoe
