Originally posted by Z3_GoCar@Nov 14 2005, 10:08 PM
So, maybe outline the process that needs to be performed and any place I might be able to help. Thanks,
James
[snapback]65357[/snapback]
James,
The Rules Making process is outlined in the "Garage" section of the SCCA.com site...
As for making a class above ITS... Here's what I think it would take...
You guys who would commit to such a class need to write letters to the CRB in the form of classification requests for the cars in question. I'd personally do a seperate request for each car, which may be necessary anyhow since you need to fill out a VTS sheet for each one...
With that done, send them to the CRB, via the SCCA tech department with the appropriate request and data...
I think if we could show enough interest, we could get this done. We've already had to turn cars down because they could not be made to fit into ITS, so those would be back on the table as well and would be considered along with these requests...
Get started now! That would give us until next August to work out the details and see if we could put a package together that would fly...
Not sure about the weight, but when we've played around with it, the E36 would come in in such a class at around 2700lbs... 300Z perhaps at 3050lbs, etc... It would all depend on the range of cars and what would seem like a reasonable target wt/pwr ratio for the class as a whole...
Write and we'll see what we can do... I don't think I'm alone in thinking that this would be a wonderful idea and would WORK!
Darin E. Jordan
Renton, WA
