Results 1 to 10 of 10
Thread: Dry Sump
    May 2004
    Phoenix, AZ
    58
    I looked at a car a week or so ago that had a dry sump. As I know little about them I would be interested in hearing some opinions regarding their usefulness.
    #63 ITB VW GTI
    #63 T3 Mazda RX8
    AZ & CalClub Regions SCCA
    Jun 2005
    Kansas
    532
    Errrr.... Dry sump? IT car? Last time I looked, dry sump systems were expressly forbidden in IT unless the car came with the system from the factory.
    Having said that, their usefulness is manifold... more horsepower, better lubrication, lower oil temps, etc.
    Gary Learned
    MiDiv
    Volvo 142E
    Buffalo, New York
    2,942
    Outside of IT...very useful.
    Reduces the oil in the sump, thereby reducing or eliminating "windage"--parasitic drag on the crank caused by oil roping around the crank from the sump.
    Has cooling benefits, also.
    Nov 2001
    Somewhere in the swamps of Jersey
    399
    A dry sump also allows the engine to be mounted lower in the chassis (lack of a bulky oil pan) for better CG, etc.
    Hero To The Momentum Challenged
    May 2004
    Phoenix, AZ
    58
    You are correct sir! This wouldn't be for IT. Disadvantages???
    #63 ITB VW GTI
    #63 T3 Mazda RX8
    Mar 2001
    Connecticut
    7,381
    Addtional costs ($$$) and complexity.
    Development time if someone hasn't already done it.
    Extra pumps that can fail.
    Extra lines that can fail.
    A belt that can fail.
    Flagtown, NJ USA
    6,335
    15-20 Qts of oil, per change, as opposed to 5-8. At $4-$8/Qt, that adds up.
    Aug 2005
    1,717
    [snapback]63818[/snapback]
    Don't forget extra tank that can fail/ be puctured in off track incidents
    James
    STU BMW Z3 2.5liter
    Jul 2004
    59
    Depending on the install and design there is a HP increase that come from the increase in crank case vacuum.
    May 2005
    Staying off the walls
    1,049
    Having dicked with a dry sump on a CFC I'll give you my $.02 in order of decreasing importance.
    Advantages
    1. Oil pump always has a steady supply of air free oil that is not effected by g-forces.
    2. Allows engine to be mounted as low as possible in the frame.
    3. You decide how much oil you want in the car (as little a 3 qt to a 55 gal drum if you wanted.
    4. You decide what pump, how fast you want to spin it, and where you want to scavange from.
    5. Little or no oil in the sump eliminates windage for more HP at high rpms.
    6. It looks cool
    Disadvantages
    1. Cost
    2. Weight
    3. Leaks
    4. Additional maintanence
    5. Complexity (more of everything like hoses, fittings, etc.)
    IMO without a doubt the best way to oil your engine on a car if you race. If it was legal in IT my car would have one.
    Tom Sprecher
