Ok so I have the motor into the car and everything running. I set the timing at 12degrees and went on to set my fuel enrichment. I hooked up the harness, set my meter to the 200mA range and I am getting a reading of 20.35. This is well out of the 1-16mA spec.
So far I have heard check the O2 sensor. But I went sniffing around and the only thing I found is if the O2 is bad that it wouldn't swing around. However, noone mentions what would happen if its reading out of spec as to what to check next.
This car is supposed to be on the track on Friday for its shakedown and right now unless I can figure out what is going on, I dont know if I will have that chance.
I could use as much help and suggestions as I can get right now.
