Couple questions:
- hit the wall and flattened the driver's side, most likely also pushing the axle toward the psngr side
- straightened frame, now rear end sits about 1/2 to 3/4 inch further out of the passenger side fender well
- measuring wheel to frame underneath, there is the same discrepency (frame straight, axle mounting bad somewhere?)
- when removing the rear end, looks like maybe the brackets that hold the trailing arms might have been tweaked, tho it's hard to tell for sure.
- I suppose the trailing arms could be tweaked, hard to tell since they would all be tweaked? I am running stock bushings which seem to have quite a bit of play tho.
- if the brackets on the axle are tweaked, can they be straightened and/or gussetted/welded?
- The Watts link pivots, so I wouldn't think that those links would get mashed?
- Do I "just" replace all arms and rear end?
PS: I don't neccessarily want to continue down the RX-7 path in the future
