I am racing at Lime Rock this weenend and at WGI next month. I just bought a brand new set of Toyo Proxes for my RX-7 ('84) and don't know what people set their tire pressures at for these tires. Any recommendations?
#94 ST-4 RX-7 EMRA
I find somewhere around 35# hot is about right. YPMV (your pressure may vary)Originally posted by Ben 84 RX-7@Sep 20 2005, 09:30 PM
[snapback]60739[/snapback]
Never underestimate a man that owns a Sawzall and a welder.
I usually run 38 lb hot with the RA-1's on the Spec7. Again, you may want something else. If the track is predominantly right turns, I start my pressures @ 31(LF), 32(LR), 33(RR), and 34(RF). The hot pressures are generally within 1 lb of each other and I adjust from there.
Jeff
38 Hot seems to work on just about everything I've raced on Toyos. I start at about 30 cold, in toasty Southern California.
John Norris
ITR E36 BMW "sprint car" & ITS E36 "enduro car"
"I vas too fast for racing and too low for flying"
Hans Stuck jr
Me too... Ra/1's at 38 hot; once you get to 40 they start sliding a lot, over 40 and your are ice skating or rallying....
Marcus
Marcus
miller-motorsports.com - Its always an Adventure (and woefully outdated)
1.6 ITE/SPU/ST2 Turbo Miata (in pieces... err progress)
Wow! I was told to run 22-24 psi cold on my recently aquired IT7. The tires on the car and the spares look good across the tread but tire temps would be a better guage. I wonder why the difference?
Tom Sprecher
I've run my car that low, its not very nice, as compared to my normal 29/30 cold.
Marcus
Well, I took your advice and ran them at 30 psi cold and it stuck like glue! It handled so well that I didn't even experiment with other pressures. Thanks for the help!
Now if only my panhard connection on the drivers side hadn't broken off the rear end at the apex of the right hander at the bottom of the hill at Lime Rock! A bit of a scary moment!
#94 ST-4 RX-7 EMRA
Gald to hear they worked out for you! What had you been running previously?
Marcus
Marcus
Marcus
[snapback]61256[/snapback]
4 year old, rock hard, cracked Kumho Victo's with some cord showing...Still have them if you want to buy them!!
#94 ST-4 RX-7 EMRA
